front lower control arm bolt - JeepForum.com
post #1 of 8 Old 11-23-2013, 05:08 PM Thread Starter
97ZJ_FOORx4
I'm in the middle of installing my lift and need to remove the control arms. I got the nut off the front lower control arm bolt on the axle mounts, but it hits the diff when trying to pull the bolt out. Its to long. Wat do?
97ZJ_FOORx4 is offline
post #2 of 8 Old 11-23-2013, 05:18 PM
PolkaPower
Did you take the bolt out of the other end too?
PolkaPower is offline
post #3 of 8 Old 11-23-2013, 05:23 PM Thread Starter
97ZJ_FOORx4
Yup. The lower control arm on the drivers side is just held by the bolt on the axle side.
post #4 of 8 Old 11-23-2013, 05:44 PM
bigbill888
When I did this, I had to cut the bolt with a sawzall because it was hopelessly rust welded to the steel sleeve inside the cushion.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 8 Old 11-23-2013, 05:51 PM Thread Starter
97ZJ_FOORx4
Lol I just got it out. I guess taking a break for a minute and thinking things through help. I twisted the control arm until the bolt could slide underneath the diff.i had the frame side already out and down.
Thanks
post #6 of 8 Old 11-23-2013, 05:54 PM
PolkaPower
Yea if you get one end of the bolt out you can twist the arm. But you know that now lol
post #7 of 8 Old 11-23-2013, 06:01 PM Thread Starter
97ZJ_FOORx4
Now on to the uppers, then springs, then the new stuff can go on. Yay.
post #8 of 8 Old 11-23-2013, 06:06 PM
PolkaPower
The uppers suck because the axle will roll forward.
