Front Locker HELP - JeepForum.com
post #1 of 14 Old 06-04-2013, 04:58 PM Thread Starter
lil_joe
Front Locker HELP
Someone please clear this up for me, I thought I had done plenty of research, and used the search feature several times with no avail.
I was planning on installing a Lock Right locker in the front of my 97 ZJ, I have completed the 242 swap. The problem being, is that a friend of mine who has 98 ZJ also has a Lock Right, but has locking hubs. He says that without the locking hubs I won't be able to turn.
Can someone please confirm or deny his claims, the locker is sitting in my garage ready to install.
HELP.........PLEASE
Thanks,
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #2 of 14 Old 06-04-2013, 06:17 PM
JakeC132
i have a spartan lockers in the hp 30 front and 8.8 rear of my zj. with a 231 swap of course and i can turn fine. i don't have manual locking hubs. just running a hp dana 30 with stock hubs. You should be fine as long as you have a 2 wheel drive option for the road. turning in 4x4 with locked front and rear is always gonna be tough.
JakeC132 is offline
post #3 of 14 Old 06-04-2013, 06:19 PM Thread Starter
lil_joe
I do have the option of 2wd, but I have the stock LP D30
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
post #4 of 14 Old 06-04-2013, 06:31 PM
WhiteOut
WhiteOut's Avatar
You're fine.
Install then and then tell him it's magic.
WhiteOut is offline
post #5 of 14 Old 06-04-2013, 06:39 PM Thread Starter
lil_joe
Ive taken your advice before White Out, I'll let you know on Sunday.
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
post #6 of 14 Old 06-04-2013, 06:50 PM
riot1987
Youll be fine. Youd really feel it with a full time case. Running it in 2wd on pavement will be ok you may still feel it in tight turns though
Build thread^^
riot1987 is offline
post #7 of 14 Old 06-04-2013, 08:15 PM
Technohead
I'd recommend locking your rear axle with a Spartan instead. All else being equal a rear locker will get you further down the trail than a front locker.
-Eric
Technohead is offline
post #8 of 14 Old 06-04-2013, 09:56 PM Thread Starter
lil_joe
The general consensus in AZ wheeling is to have the front locked, as said before, I have the Lock Right already, but thanks
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
post #9 of 14 Old 06-05-2013, 06:21 AM
Technohead
General consensus cannot negate the laws of physics. . . .
-Eric
post #10 of 14 Old 06-05-2013, 10:58 AM
KingtheZJ
i would take front locker over rear locker any day.
as said, front lunchbox locker with unit bearings and 2wd case is fine
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #11 of 14 Old 06-05-2013, 11:20 AM
Crasher
I run the trails east of Florence and at Table Mesa with both of my rigs and IMHO a locker in the rear first did the most for me. I only have to turn the front on in a few spots on trails like LT, Predator, and Elvis. You'll like it in the front, but my choice would be the rear first/also.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #12 of 14 Old 06-05-2013, 11:24 AM
tucsonzj
just stay off the skinny pedal during tight turns. And expect some fun looks when you pull up behind someone in a gas station lol.
But yea i'd take a rear locker first. But set it up as you want.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #13 of 14 Old 06-05-2013, 11:58 AM
Crasher
I used to have an aussie in the front and a Lock-rite in the rear with a 231 tc. In 2wd, I never knew the front locker was there under any power condition. I could hear a light clicking sound in turns. In 4lo, tight turns offroad on a hard surface was a little binding. One tire had to slip a little and sometimes the locker would release with a bang. All normal. I never had occasion to drive on icy or snowy conditions, but imagine that it could get dicey in 4wd. With the selectable lockers, as long as I can keep all four tires on the ground, I don't turn them on.
Crasher is offline
post #14 of 14 Old 06-05-2013, 03:11 PM
JohnnyZJ
rear over front. that way you can turn tight, drive your 4x4 on icy roads and going fast in 2wd is a lot more fun.
i have buddies that run the aussie up front and they don't have issues though. except on the road in 4wd.
07' JKUR rollin on 35s
JohnnyZJ is offline
