Front end work - JeepForum.com
post #1 of 7 Old 05-02-2014, 09:32 PM Thread Starter
streetzj
Front end work
MyJeep needs a ton of front end work. Ball joints, shocks, and then that trackbar. But that assembly concerns me the most -- is it attached to that horizontal shock? Is it also attached to the tie rods? How expensive is all that stuff and how difficult is it to replace? The sway bar is ok!
streetzj is offline
post #2 of 7 Old 05-02-2014, 11:56 PM
Myusername1674
The trackbar attaches from the passenger side of the front axle, to the drivers side frame via a bracket. I'm assuming by horizontal shock you mean steering stabilizer? That is attached to the drag link. Are you sure you need a track bar?
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 7 Old 05-02-2014, 11:58 PM
Myusername1674
This is helpful, from an xj but pretty much the same
(in progress)
post #4 of 7 Old 05-03-2014, 01:33 AM
Uniblurb
Uniblurb's Avatar
Here's a real good thread by coralman on replacing most the front end parts you mentioned.
http://www.jeepforum.com/forum/f13/c.../#post15387705
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #5 of 7 Old 05-03-2014, 01:50 AM Thread Starter
streetzj
oh man, you guys are awesome -- i found that same image and made a really crappy copy to show you my problems.
the red circles are the joints that look like crap to me, but i've been driving on them this way for almost three years.
the yellow bar seems to split off and go to the pitman arm and both wheels. it looks like all of these are worn connections, correct? what piece is this?
the green bar is the steering stabilizer, and that looks ok.
the blue bar is a sold bar that goes from the steering stabilizer and something more solid, but that looks ok.
not highlighted are the sway bar links -- i did those two years ago and they seem fine.
so am i just looking at replacing that yellow bar, which appears to have tie rod ends? How difficult? would i need an alignment afterward?
Thanks!
streetzj is offline
post #6 of 7 Old 05-03-2014, 04:10 AM Thread Starter
streetzj
ok, so it seems i just need a tie rod end for the driver's side, a long tie rod end for the passenger side, and a tie rod end for the pitman arm?
streetzj is offline
post #7 of 7 Old 05-03-2014, 08:49 AM
Uniblurb
Uniblurb's Avatar
How are you judging these are worn out? Keep in mind they're ball/socket connections where they'll swivel some and won't always be straight up/down.
Jack the front end up some, leave the tires on the ground, then have someone else turn the steering back/forth while you're looking for loose parts/joints. You can also use a pry bar to try to move them up/down to see if there's slop/play in the ball/socket itself.
To check your ball joints jack a front end tire up about 3-4" off the ground, stick a 2x4 under the tire from the front then have someone lift it up/down while you're looking at the upper/lower ball joint for play/slop. There shouldn't be any if they're still good.
When replacing tie rod ends start hosing the threads down ahead of time with rust cutter. You'll most likely have to put some heat to the threads/sleeve, particularly if you live in the salt/rust belt. Measure the threads in the pipes on the old ones and try to tighten a new one in the same length. But you'll probably still need an alignment after all this front end work. Good luck!
Uniblurb is offline
