front end wobble - JeepForum.com
post #1 of 9 Old 07-14-2011, 09:14 PM Thread Starter
fej68
front end wobble
Not all the time but if I'm goin say 60 mph and hit a bump in the road it has this crazy *** wobble goin out of control like. I think it's my shocks or steering stabilizer, probably been on there since 96'. 1996 grand cherokee,4.0 4x4 selec trac, stock as a rock. Thanks if anybody can help me.
fej68 is offline
post #2 of 9 Old 07-14-2011, 11:21 PM
vonericsen
Search for death wobble on the forum. You will find a lot of info to figure out what is causing it.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #3 of 9 Old 07-15-2011, 12:26 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Death wobble has so many causes it would take less time for you to search and read three threads than to type everything out for you.
ratmonkey is offline
post #4 of 9 Old 07-16-2011, 06:49 AM Thread Starter
fej68
front end wobble
So that crazy death wobble can occur on a stock ride. I thought it only happened when you lifted it like 4" or so. Thanks I'll check out some other posts and try to figure this thing out.
fej68 is offline
post #5 of 9 Old 07-16-2011, 02:36 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
any vehicle with a solid front axle can get death wobble.
post #6 of 9 Old 07-16-2011, 05:34 PM
Oldfrog
2007 WK
Yes, it can occur on a stock ZJ. Mine was cured with a new track bar and steering damper.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 9 Old 07-16-2011, 05:36 PM
gothchick
x2 QFT.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #8 of 9 Old 07-17-2011, 03:56 AM Thread Starter
fej68
Sounds like It's time to do some upgrades on the ole zj front end, might as well get a lift while I'm down there
fej68 is offline
post #9 of 9 Old 07-17-2011, 04:00 AM
Billy
woo! lift! make it a 3 inch! and some 32's!
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
front end wobble tomc77 ZJ Grand Cherokee Forum 0 06-14-2010 11:10 AM
zj front end noise and wobble ryan-5.2zj ZJ Grand Cherokee Forum 1 01-10-2008 07:52 AM
front end wobble alexofc69 ZJ Grand Cherokee Forum 6 08-01-2007 11:52 AM
'97 ZJ Steering/Front End Wobble pctech ZJ Grand Cherokee Forum 12 06-26-2005 04:04 PM
Front end wobble when braking Rojo 5 ZJ Grand Cherokee Forum 7 10-11-2004 07:59 PM
