Front end vibe for a few seconds, not DW - JeepForum.com
post #1 of 7 Old 07-19-2009, 04:35 PM Thread Starter
Greeeeenberg
So i can drive my jeep at 70-75 and its smooth as heck. However sometimes i get a vibe like im goin over a rumble strip (which im not) for a few seconds then it disappears and i dont get it for a long time. I dont know if it is an early warning of something failing, like wheel bearing or cv shaft, or if its just spots in the road. It seems to be coming from the front right passenger. Im trying to figure it out but really dont know where to look. I know it isnt the tires out of balance. Any suggestions would be helpful.
Thanks guys.
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #2 of 7 Old 07-19-2009, 05:17 PM
Bama_WJ
Bama_WJ's Avatar
How long since you replaced the steering stabilizer?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #3 of 7 Old 07-19-2009, 05:24 PM Thread Starter
Greeeeenberg
Probably the original. I bought the jeep this past december and have but about 12,000 mi on it. Only things ive done, oil and regular stuff like that, water pump, front shocks, tires, many car washes, and soon transfer case swap, diff fluid change, and tranny filter/fluid change. Any way to tell if there shot?
Member #1
post #4 of 7 Old 07-19-2009, 05:28 PM
Bama_WJ
Bama_WJ's Avatar
You could take off the original steering stabilizer and see how easy it is to move in and out. I would start with that. They are cheap to replace as well, somewhere in the range of $40.
Daniel
Bama_WJ is offline
post #5 of 7 Old 07-19-2009, 05:56 PM Thread Starter
Greeeeenberg
Guess i could start with that. Pull that off in a little bit or tomorrow and test it.
Member #1
post #6 of 7 Old 07-21-2009, 06:24 PM Thread Starter
Greeeeenberg
The bolts are seized so i sprayed the heck out of them and will have to wait til tomorrow. Today i drove it for a while and it didnt do it once. Partly confused.
Member #1
post #7 of 7 Old 07-21-2009, 07:09 PM
Bama_WJ
Bama_WJ's Avatar
If the penatrating oil doesn't work, try heating the bolts up.
Daniel
Bama_WJ is offline
my zj will start and run but only for a couple seconds thegrand ZJ Grand Cherokee Forum 16 08-20-2009 09:40 AM
Hum or slight vibe to the front end after 2"bb? crashcraddock ZJ Grand Cherokee Forum 3 05-06-2009 09:20 AM
please help zj front end humming/vibe zjsheepjeep ZJ Grand Cherokee Forum 4 02-24-2009 02:46 PM
front clunk noise at idle every 15 seconds on 2001 GC twojeeps9401 ZJ Grand Cherokee Forum 4 11-28-2008 02:07 AM
5 seconds startups, 93 JGC 4.0 ltr joedn ZJ Grand Cherokee Forum 4 08-29-2006 10:03 AM
