Front end thumping at low speed - JeepForum.com
post #1 of 15 Old 05-09-2012, 09:06 PM Thread Starter
goatmurray
My jeep has recently started making a thumping/banging sound in the front end. It's a repeating sound, and the faster the wheels are spinning, the faster the banging is. At first I thought it was a u-joint or the gears in the differential, but I'm no mechanic. Sounds something like that, though.
It likes to do it when I'm creeping through a parking lot either coasting, stopping, or on the gas very lightly. Only does it sometimes, seems like more often when it's warmed up, but I don't stop much until after its warmed up anyway...
I noticed it started right around the time I changed my front diff fluid. I was careful to keep it clean inside and put 75-90 in the first time with mopar friction modifier. Night before last I changed it again to 90-140 to see if that would quiet it down. No effect.
It's a |6 automatic with selectrac.
It's louder and more likely to happen if my sway bar is disconnected.
Pretty much all the bushings on the RE 4.5 lift are shot. Maybe that's it?
goatmurray is offline
post #2 of 15 Old 05-10-2012, 05:01 PM Thread Starter
goatmurray
Nobody?
post #3 of 15 Old 05-10-2012, 05:12 PM
PolkaPower
Bad bushings can cause thumping. You don't need friction modifier in the front.
PolkaPower is online now
post #4 of 15 Old 05-10-2012, 09:19 PM
westcoastvibes
I had all kinds of thumping and clunking, after a thorough looking I ended up replacing both lower control arms, both sway bar end links (not the bushings but the whole dog bone assembly) and the shocks. turns out the PO replaced the shocks and put sub par bolts that were undersized causing the shocks to clunk, the control arm bushings were so loose that they just fell out when the bolts were removed and the sway bar end links had no bushing left in them at all. It took me a while but the clunks and bumps are all gone now.
westcoastvibes is offline
post #5 of 15 Old 05-11-2012, 12:49 AM
PolkaPower
Kinda weird that you have a4.5" lift and can't figure out if it's the worn out control arm bushings or not. It would seem to me like you have had it long enough that you would know better that if you have worn bushing, they need replacing.
post #6 of 15 Old 05-14-2012, 08:56 PM Thread Starter
goatmurray
Oh I definately need new bushings... That need has been identified from day -1.
And it makes a thumping, thunking, creaking sound every time anybody looks at it, but this thumping isnt just a solitary thump when I accelerate or hit the brakes.
It almost sounds like a U-joint is really sloppy and is being turned at excessive angles, but it's not the front driveline from what I can tell.
My brother said it sounds like a spider gear keeps trying to grab, but let's go. (IDK)
What it REALLY sounds like is a fender rubbing on tire tread, but there's no way that's what it is. And it sounds metal-on-metal. And it's not quite as fast as fender on tread.
Assuming the previous owner had a LSD installed, and I didnt put friction modifier in it, what would it sound like?
I'm pretty sure the rear diff is limited slip... not positive about the front.
post #7 of 15 Old 05-14-2012, 09:09 PM
TheHalfWit
What'd you see when you dropped the diff cover?
If you saw this then its open and doesn't require anything special.
That aside, fix what you know is broke i.e. the control arm bushings, than try troubleshooting it. Personally I just had one look at my jeeps 17 year old, mostly original suspension and ripped everything but the ball joints out and rebuilt it figuring that if the control arm bushings were dry rotted, every other bit of rubber down there was in the same condition and needed replacing to be free of clunks/squeaks.
Speed based though I'd try wiggling each of the U-joints, maybe see if all your caliper bolts are snug (funny as that sounds.)
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #8 of 15 Old 05-17-2012, 08:37 PM Thread Starter
goatmurray
I didnt see that^.
I don't recall seeing a differential case like that.
post #9 of 15 Old 05-17-2012, 08:44 PM
jtackerman28
Originally Posted by goatmurray
I didnt see that^.
Front axle u joint. Not drive shafts. I bet they are about to fall out.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #10 of 15 Old 05-30-2012, 01:33 PM Thread Starter
goatmurray
My Jeep has stopped making the sound...
U-joints seem fine, though.
post #11 of 15 Old 02-17-2013, 01:51 PM Thread Starter
goatmurray
Dunno how I missed it, but you were right. U-joints were about to fall out.
I should make a video, it'd blow your mind.
post #12 of 15 Old 02-17-2013, 04:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Engine mounts? Does the the "thunk" occur during acceleration and just after braking?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #13 of 15 Old 02-17-2013, 05:34 PM Thread Starter
goatmurray
Thanks, but I resolved it. It was the axle U-joints. They were long gone. Like I said, I don't know how I missed it. Thanks for the responses!
On the subject of thumps, though, does anyone know where could get some rear lower control arms for a RE 4.5" long arm kit? Mine got bashed open by the PO. I heard RE went out of business??
post #14 of 15 Old 02-17-2013, 06:07 PM
PolkaPower
You mean these guys http://www.rubiconexpress.com/
They did for a while but they are back.
post #15 of 15 Old 02-18-2013, 07:14 PM Thread Starter
goatmurray
Hmmm Son of a gun.
Thanks!
Thumping noise in front end? streetzj ZJ Grand Cherokee Forum 1 11-17-2011 04:23 PM
zj front end thumping noise? Devanzj ZJ Grand Cherokee Forum 2 01-26-2011 10:50 PM
Front end vibration at speed rickd. ZJ Grand Cherokee Forum 9 03-29-2006 04:16 PM
Thumping noise in front hub are duse_500_2001 ZJ Grand Cherokee Forum 7 10-28-2005 07:41 AM
Front End Thumping During Icy Weather Astorm ZJ Grand Cherokee Forum 2 02-24-2005 12:22 PM
