front end pulls - JeepForum.com
post #1 of 5 Old 11-27-2013, 12:06 AM Thread Starter
baggman
front end pulls
i have a '98 grand 4x4 with the front driver side tire going bald on the inside.
the outside of the tire has good tread on it. it also seems to want to pull to the right(passenger) side when driving. the passenger side tire looks good with no signs of uneven wear. can somebody tell me what may be causing this and what can be done? thanks in advance.....
baggman is offline
post #2 of 5 Old 11-27-2013, 12:28 AM
kg6mov
Hears the voices
kg6mov's Avatar
A great many things,
Shake test for balljoints, hubs, and tre's. Check your toe with a tape measure, be sure to check with vehicle weight on the axle.
Then check CA bushings, they're probably shot anyway.
kg6mov is offline
post #3 of 5 Old 11-27-2013, 12:29 AM
AVR2
I had the same issue, but on the passenger side with my KJ. The outer part of the tire had normal-looking tread, the inner part was close to bald. Driver-side tire was fine. The fix was new tires and an alignment - it's bad alignment that causes the problem in the first place, but I couldn't give you the technical details on exactly what was wrong and why.
AVR2 is offline
post #4 of 5 Old 11-27-2013, 12:54 AM
newfieZJ
New lower front control arm bushings , those are a given if original . Not the issue , just put it on your 'list' . They can knock the castor outta position and cause your pull due to road sloping
Inspect the front end . Have someone move the steering wheel back and forth and look at each joint . Even wrap your hand carefully around the joint , you will feel a bad joint . Don't get pinched . Have the wheels on the ground for this , it "loads" the steering parts . That should do your tie rods and track bar . For the ball joints , you need to jack up the axle , and raise the tire enough to get a pry bar in there , pry up and down with your hand on the tire at 12 o'clock , you will feel any play . Place your hand on the wheel at 12 and 6 , try to wiggle it . If play is felt , issue may be the wheel bearing . Have someone else use the bry bar , repeat the ball joint test but visually look at the ball joints this time .
If not comfortable with this , have a mechanic do an inspection for you . Indications are you have an issue , safety first !
Checking your toe after an inspection is a great idea . You ideally want to see about 1/16-3/32nd's toe in if in spec . I bring mine as close to 0 as possible showing a slight hint of toe in . Just pulled 60k out of a set of tires I bought new , rotated them once during that time . Very even wear from an AWD .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #5 of 5 Old 11-27-2013, 06:12 PM Thread Starter
baggman
Thanks to all for the quick response. Yes, I can clearly see the control arm bushings are bad, have yet to check the ball joints. No one mentioned it, but I was wondering if that damper might come into play with all this. How can I tell when it needs to be replaced? Thanks again.
baggman is offline
