Front end noise 98 GC, not sway bar links - JeepForum.com
post #1 of 4 Old 07-23-2003, 12:20 PM Thread Starter
techie
I have a 98 GC. I have a rattle/clunking noise that is getting worse. I'm going to take it in, but I always like to try to figure out what it is and what a reasonable expected cost is before I take it in and they give me the full pitch.
I replaced the sway bar links about 10k ago, they look fine. The noise seems to be on the drivers side. It happens at lower speeds and is worse when making right turns. I looked at the steering box and the three bolts seem fine.
The noise sounds similar to what the sway bar links sounded like before I had them replaced, except it's louder and more distinct.
What else could it be besides the links or steering box, and seem to be more from the drivers side.
Any input is greatly appreciated
Thanks
techie is offline
post #2 of 4 Old 07-25-2003, 12:53 AM
Colorado 5.9
Colorado 5.9's Avatar
It could be a loose track-bar bolt or loose control arm bolt. If any of the four bolts are not loose. One or more of the bushings could be trashed.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #3 of 4 Old 07-25-2003, 07:22 AM Thread Starter
techie
Thanks, I'll take a look at those.
techie is offline
post #4 of 4 Old 09-05-2003, 12:49 PM Thread Starter
techie
Update, if anyone cares, it was because of my transfer case bushing being worn. My Catalytic converter is making some noise so they are going to replace it under warranty since I'm under 8/80
techie is offline
IRO 3" + Front Sway Bar Links VT_WJ_2000 ZJ Grand Cherokee Forum 11 10-06-2009 08:12 AM
Sway Bar Links (Front) Magikal_ZJ ZJ Grand Cherokee Forum 4 07-04-2009 10:00 AM
Front sway bar end links - 98 ZJ 4WD dave1998ZJ ZJ Grand Cherokee Forum 4 09-22-2008 03:26 PM
Front Sway Bar Links wjdave ZJ Grand Cherokee Forum 8 10-24-2006 07:05 PM
Factory ZJ Front Sway Bar w/ links, used TN PlatinumZJ ZJ Grand Cherokee Forum 1 09-07-2005 08:55 AM
