Front End Horrors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Front End Horrors
WIN a Mammoth Lift Kit for your Wrangler at ExtremeTerrainFS: Wranger BRIGHT License Plate LED! Just $3! Great valuePoison Spyder JK Body Mounted Tire Carrier
Unread 07-04-2014, 10:32 PM   #1
Compgeek789
1994 ZJ
Front End Horrors
I've been noticing weird things going on in the front end for a few months now. It started with a kinda high-pitched moan from the front-left when I went over a bump slowly, especially while turning. It went on for a few weeks, until it evolved into a thunk. It was especially prominent, but recently started to settle down. A couple times, if I turned at an intersection and pressed the gas, it would let out a loud thunk, but that dissipated.
I do have a bad VC, but that's been like that for years. New upper and lower ball joints on the left, and the ones on the right are good. Somewhat new front driveshaft and new U-joints on the rear driveshaft. New tie rod end on one side of the vehicle. I also checked the shocks; they're not leaking. The vehicle doesn't make any sounds while going over bumps at speed.
It seems like whenever I fix something, that something else pops up.
Any thoughts welcome. Wanted to travel but that's now a pipe dream.
Compgeek789 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2014, 11:19 PM   #2
PolkaPower
Yea well a bad VC will wear out the front end. You are just feeding it new parts lol.
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 07-05-2014, 07:14 PM   #3
elijahpr
What he said. I thought that was the reason why people who knew they had bad VCs removed the driveshaft until they could fix them or swap out the transfer case..
1998 Grand Cherokee TSi
3-inch Rough Country Lift
elijahpr is offline   Reply With Quote Quick reply to this message
Unread 07-05-2014, 07:24 PM   #4
KJK
It's probably worn out lower control arm bushings that are clunking. It was on mine anyway. They take a beating from bumping up against parking stops over the years.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline   Reply With Quote Quick reply to this message
Unread 07-05-2014, 08:01 PM   #5
Compgeek789
1994 ZJ
I hope I didn't ruin anything too expensive.
Sent from some mud bog using JeepForum
RIP 1994 ZJ 5.2
