Front End Grinding Noise..I know this has been asked, please look. - JeepForum.com
post #1 of 5 Old 01-18-2006, 03:14 PM Thread Starter
boosoo
2000 Grand Cherokee 4x4 V8. The infamous grinding noise from the front end. Occurs at all speeds. If I'm going around 65 or so and accelerate a little bit it quiets for just a second then comes back. Here is a list of things recently replaced:
1) CV joints on front driveshaft
2) Front Wheel Bearings
3) Carrier on front end
4) Fluids; Tranny pan was dropped to make sure no metal was in it.
I'm lost, and so are 3 different mechanics. Any ideas??? I've searched the forum but no luck.
boosoo is offline
post #2 of 5 Old 01-18-2006, 03:23 PM
jeepholic
jeepholic's Avatar
When faced with this type of problem I use a $9 stethescope. It will pinpoint the problem. That means putting it on a lift with someone inside it and putting it in gear while you listen underneath. It's not my favorite place to be but that little stethescope will find the problem. I am guessing with the carrier (#3) they also did the R&P bearings.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #3 of 5 Old 07-12-2012, 05:41 PM
homless32
For a few days I have had a problem somewhere in the front end of my 07 wrangler JK. It sounds like there is some sort of scratching. I only hear the sound when I'm driving (not stopping) and I hear it louder and rougher when I am turning.
I'm suspecting it's one of the following-
U joint
Bearing
Transmition
Drive shaft
Steering stabilizer
If you have had a similar problem or know what this problem may be it would be a huge help
Thanks
homless32 is offline
post #4 of 5 Old 07-12-2012, 07:00 PM
RazorbackZJ
1994 ZJ
If your front drive shaft is a double cardon i'd check it. Drive shaft centering yoke.
RazorbackZJ is offline
post #5 of 5 Old 07-12-2012, 09:16 PM
Jeff8989
Many thanks
Jeff8989 is offline
grinding noise from up front leofanti ZJ Grand Cherokee Forum 6 08-03-2009 06:03 PM
grinding noise from front end ryan-5.2zj ZJ Grand Cherokee Forum 3 02-24-2008 02:26 PM
Help w/ front end grinding noise harlow00 ZJ Grand Cherokee Forum 0 02-05-2008 07:50 AM
Grinding Noise From Front End parnell5150 ZJ Grand Cherokee Forum 16 04-10-2007 10:14 AM
Help! What is this grinding noise from front end.. 7tiger7 ZJ Grand Cherokee Forum 4 02-17-2007 06:19 PM
