Front end grinding - JeepForum.com
post #1 of 11 Old 04-16-2013, 12:05 AM Thread Starter
cgcarpenter
There is a grind going on somewhere in the front when driving. I can't find where it's coming from and sounds like metal to metal. I checked the front diff it was good and even removed the front drive shaft and was still there.
The thing is its grinding goes away when I hit my breaks And when I'm turning. So I can only hear it when accelerating and coasting.
The breaks don't seam out of wack besides needing to be replaced soon. And the hubs were just replaced not too long ago. Any help on what it is would be great. 97 i6 242 transfer case
cgcarpenter is offline
post #2 of 11 Old 04-16-2013, 11:36 AM
gs69350
Sounds like the unit/hub bearings.
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #3 of 11 Old 04-16-2013, 12:30 PM Thread Starter
cgcarpenter
I just replaced it already before this happened. But I'm gonna take it off and check it just to be sure
post #4 of 11 Old 04-16-2013, 02:40 PM
gs69350
Torque them with a torque wrench?
gs69350 is offline
post #5 of 11 Old 04-16-2013, 03:12 PM Thread Starter
cgcarpenter
Yeah I did but I'm gonna take it off and check them still
post #6 of 11 Old 04-18-2013, 05:40 PM Thread Starter
cgcarpenter
We'll not my hubs. My axle shafts are fine. Replaced my brake pads.
Still getting the noise. Not sure where to go. But it seems to be coming from my differential. But when I opened it up it seemed fine and nothing seemed outta place. Then again I'm no gear expert.
What could be coming from there but go away when I hit my brakes that's why I'm so b
post #7 of 11 Old 04-18-2013, 05:41 PM Thread Starter
cgcarpenter
Baffled.
Any help guys?
post #8 of 11 Old 04-18-2013, 05:44 PM
kg6mov
Hears the voices
kg6mov's Avatar
Pinion bearing? Do you have a full time case? If so pull the front DS and see it that changes it.
Edit: Theres a procedure to run without shafts so you can confirm that it's the diff, time to take it to somebody who knows diffs, or call it DOA and swap in a JY axle.
kg6mov is offline
post #9 of 11 Old 04-18-2013, 05:56 PM Thread Starter
cgcarpenter
No I've got a 242
And I've already ran with out the drive shaft and it was no different.
Any link to that procedure with put that axle shafts? I'd like to try that before spending money.
Kinda low on the dough now days. Hah
post #10 of 11 Old 04-18-2013, 06:05 PM
riot1987
Originally Posted by cgcarpenter View Post
No I've got a 242
Even w/o the drive shaft that pinion gear is still rotating. It could still be making noise even w/o a front ds
Build thread^^
riot1987 is offline
post #11 of 11 Old 04-18-2013, 06:24 PM Thread Starter
cgcarpenter
I didn't have any up/down or side to side movement in the yolk on the diff. Everything seemed tight any other way to check pinion?
