Front end clunk when turning and under compression or extension - JeepForum.com
post #1 of 5 Old 06-22-2009, 05:50 AM Thread Starter
FirefightinWJ
I've had a gremlin clunk pop up on my WJ. It began about a week after I installed my UC springs and IRO links. Note, the links were used, but the bushings appeared to be in good shape. The clunk started during a wheeling trip at Silver Lake Sand Dunes (lots of high speed suspension flexion which I'm sure had alot to do with it).
Basically, I get a clunk, mainly from the drivers side, when I turn out of a driveway, onto a side street, etc. The clunk only occurs when the suspension either compresses or extends during the turn (i.e. entering or exiting my sloped driveway). Initial suspicion was and still is sway bar related, but I'm having issues narrowing down the culprit. Everything has been checked for tightness also.
Any thoughts/suggestions?
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #2 of 5 Old 06-22-2009, 04:31 PM
kentman
kentman's Avatar
2006 XK Commander
Please let me know if you find an answer. I have the same problem on our XK, and I am completely stock. It is pretty annoying. I can find nothing lose or broken-looking. I can usually work around the problem with gradual turns and softer braking, but it is annoying. I heard the valet clunk it at brunch a few weeks ago. It surely does not seem like a $45K vehicle at that very moment in time. It sounds like you just hit a small animal inadvertently.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #3 of 5 Old 06-22-2009, 04:49 PM
Toliver09
1991 XJ Cherokee
have you checked the trac bar axle mount? it likes to work loose over time
98% of drivers say "oh crap" when they see snow, the other 2% are Central Illinoisans that say "Hold my beer and watch this!"
Toliver09 is offline
post #4 of 5 Old 06-22-2009, 07:14 PM
moparrr07
chances are its a sway bar link, as it only makes the noise when the suspention is flexing, chances are thats why the person was selling the end links
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #5 of 5 Old 06-22-2009, 08:18 PM
vansskaterfreek
mine does the same thing.... when i move the sway bar with my hand, right where the link is, you can see the ball in the socket on the link moving up and down....
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
Clunk when turning at low speeds HELP! 98zjteen ZJ Grand Cherokee Forum 71 11-03-2014 11:00 AM
pop sound when turning left... and a clunk K10roc ZJ Grand Cherokee Forum 6 12-10-2009 07:52 PM
loud clunk when turning dmolaver15 ZJ Grand Cherokee Forum 5 07-28-2008 02:44 PM
Clunk in Front When Braking and Turning Astorm ZJ Grand Cherokee Forum 23 02-03-2007 01:17 PM
Front clunk on turning finally diagnosed HighLonesome ZJ Grand Cherokee Forum 8 08-29-2006 11:53 AM
