12-30-2007, 08:26 PM
#1
well I was wheeling today and my front u joints started squeaking. and rather than do it myself I'm just gunna have the thing rebuilt if I can find a place locally. my question is if I pull the shaft will any fluild leak out of the tc?
btw I have a np231
95 zj, 4.5", 32" bfg at, locked rear.
12-30-2007, 08:33 PM
#2
nope, you can do that without hurting a thing. removing the rear DS will leak fluid, but not the front.
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
12-30-2007, 08:41 PM
#3
thanks man.
12-30-2007, 08:43 PM
#4
 I second that
[URL="http://www.jeepforum.com/forum/f22/gibs-third-jeep-tj-1134746/"][SIZE="3"][B]My 05 TJ[/B][/SIZE][/URL]
12-30-2007, 10:55 PM
#5
Are you sure the u-joints are squeaking? Usually a bad bearing in the hub will lead to that. Regardless, neither are too terribly difficult to replace with the help of a friend.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
12-30-2007, 11:14 PM
#6
it only does it in 4wd.
12-30-2007, 11:29 PM
#7
Nevermind. You're talking about the driveshaft u-joint, not axle one probably.
-Kyle
1996 Grand Cherokee
1996 ZJ FOR SALE
12-30-2007, 11:41 PM
#8
yep I'm talking about the driveshaft u joint
01-01-2008, 06:30 PM
#9
besides u joints what what else goes into rebuilding a shaft?
01-01-2008, 08:14 PM
#10
Mr. Hyde!
Nothing afaik...perhaps rebalancing it. If you're going to have it rebalanced, and you 4-wheel, you might as well just have a new bigger diameter shaft built (with slightly thinner tubing).
01-01-2008, 08:35 PM
#11
If you have the dual cardan type shaft you probably should change the centering ball assembly when you change the u-joints. It is a cause of noise in the front driveline (often noted as angry squirrels ).
Here is a great write up on changing it from Stu Olsen's website.........
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
Good luck.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
01-01-2008, 09:24 PM
#12
Mine was squeeking too and it was the CV joint with the two U joints and the ball. Make sure you do the ball too.
01-01-2008, 09:35 PM
#13
is that ball deal pretty straight foward to change
01-01-2008, 10:12 PM
#14
It's easier than the 3" ZJ body lift in your sig.
Russ
01-01-2008, 10:44 PM
#15
I had a guy in my local jeep club tell me i could do a body lift on my dub... he dosen't come to very many functions anymore
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
