front driveshaft removal for diagnosis
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
My Jeep is a 94 ZJ with a 5.2L and I'm not sure the transfer case. It's all time 4x4 is all I know.
I've been dealing with a vibration issue at high freeway speeds and was curious if I can remove the drive shaft and drive the vehicle at high speed on the freeway. I want to test if the drive shaft could be causing the issue. Thanks, Curtis
2004 WJ Overland |
#2 |
Jeep Jedi Master
The front double carden driveshaft can be rebuilt. I don't know how many miles you have on yours though.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#3 |
I can't say for sure about removing it with the full-time four wheel drive. Someone should chime in pretty quick on that one. On the driveshaft rebuild, I just had my front one done. It cost around $180.
Mine - Black '95 5.2L ZJ, 6.5" RE hybrid lift, ARB Bumper, 33" TrXus MTs, Black Steelies, Magnaflow, K&N Black Jeep Club Member #50 Hers - '99 4.0 WJ, Platinum Silver Metallic, 2" BB, 245-75-16 BFG ATs |
#4 | |
I was hoping someone who had first hand knowldege or knew enough about the ZJ could give me a pointer.
2004 WJ Overland |
#5 |
Jeep Jedi Master
There will be some fluid loss. You'll need to cover the opening.
Hunter
#6 |
That's a great way to diagnose, if you can keep fluid in her. Maybe a large rubber stopper? Just do it for a short drive, as the transfer case needs resistance from both ends to keep the slack tight inside. I actually sheared the rear U-joint bolts once. Crawled underneath and yanked the driveshaft out and drove 50 miles home in front wheel drive.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#7 |
I drove mine around town for a day or so without the front driveshaft while I rebuilt it without any problems. The rebuild kit is $27 or somewhere around that from Napa P# 261-0617
98 ZJ 5.2, LA n Locked 35's 01 XJ 2dr, 4.0 5spd 86 MJ 07 Ram 2500 5.9 ctd |
#8 |
i had the same problem with mine. same truck, vibrating on hwy and whinning in city. was told its the viscous coupler. i take my frot driveshaft off in april and put it back on in dec with no problems and no fluid leaks. was thinking about replaceing the v.c. but it would be cheaper to swap a 249 for a 242.
#9 |
Hey I wanted to let you guys know I didn't need to remove the drivshaft. I replaced the lower front control arms today and both front bushings were torn. The vibration went away with the new control arms.
2004 WJ Overland |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
