post #1 of Old 04-30-2013, 04:16 PM Thread Starter
capcyclone
capcyclone's Avatar
Front driveshaft disconnect - 249
So, an interesting topic came up at my work today. A guy has a '97 zj with a 249 transfer case. His front driveshaft is disconnected - presumably because the VC was bad, but he doesn't really know why (it was that way when he bought it).
I'm thinking of buying it from him for my son, but would definitely want to either swap the TC or do the VC swap. If the driveshaft has been disconnected - is there anything I'd need to look at/do besides trying a VC swap, reconnecting and see where that leaves me?
"The Jeep is America's only real sports car" - Enzo Ferrari
capcyclone is offline
post #2 of Old 04-30-2013, 05:44 PM
Snowfan2
The shaft may have been removed by someone seeking better mpg. Put the shaft back in and see how she rolls.
Be sure to run it up to highway speeds and check for noise and vibes in the front diff.
Maybe the VC is toast, maybe not. I have a good 249 for cheap if you need it.
Snowfan2 is offline
post #3 of Old 05-02-2013, 09:28 PM
WkndFun
I did the same to mine when my VC went bad.. Sounded like an extremely bad wheel bearing, and anything over 40mph was impossible. I just found a rebuilt 249 off a buddy and swapped that in for the time being. A VC repair kit are really only found on Ebay and are more than a new transfer case. The VC is actually a discontinued part. Even after I swapped the TC, I kept the front driveshaft out for awhile. Or even the 2 hour road trip to the offroad park. Believe it or not, I gain almost 2mpg with it out..
WkndFun is offline
post #4 of Old 05-02-2013, 09:33 PM
WhiteOut
WhiteOut's Avatar
No you dont. With the shaft in or out, everything still rotates. There may be small gains, but nowhere near enough to measure. If you have swapped in manual hubs, then its different, but you will never make up the cost in gas savings.
WhiteOut is online now
post #5 of Old 05-02-2013, 10:27 PM
jt_armstrong
1994 ZJ
Wouldn't a new VC just sieze up if you ran it with one driveshaft disconnected?
jt_armstrong is offline
post #6 of Old 05-03-2013, 08:54 AM
PolkaPower
For you it would. 93-95 are designed different. 96+ it's ok to take the front shaft out.
PolkaPower is offline
post #7 of Old 05-03-2013, 01:52 PM Thread Starter
capcyclone
capcyclone's Avatar
In my case, I was suggesting that I'd put a new VC in and reconnect the front driveshaft. I'm one of the weird ones on this forum that likes the AWD 249.
post #8 of Old 05-03-2013, 01:58 PM
kg6mov
Hears the voices
kg6mov's Avatar
New vc and a new driveshaft, good to go. The 249 is a great case.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ 5.9 - Junked
kg6mov is offline
post #9 of Old 05-03-2013, 05:11 PM Thread Starter
capcyclone
capcyclone's Avatar
So we bought the '97 for my son. We reconnected a front drive shaft. All seems okay.
I've seen my next question asked more than a few times - but how can I determine whether the VC is bad or not? I've read about doing the figure 8s in a parking lot - and that if there is a lot of "binding" - that's a good indication of VC trouble. But can someone describe "binding" in this context? What occurs? The vehicle will have a lot of hesitation to do the turns? There will be excessive rubber marks on the ground? Both? A better description of what people mean when they say "binding" would be a big help to me here.
post #10 of Old 05-03-2013, 05:14 PM
PolkaPower
Hopping, wobbling, hard to turn, lumpy feeling, and black tire marks are sure bets.
post #11 of Old 05-03-2013, 05:27 PM
kg6mov
Hears the voices
kg6mov's Avatar
If it drives like it's in 4 part time then the vc is bad. When it dies it basically locks the shafts at the same speed and will act funny in turns.
Figure 8s are the best test. Take a drive around the neighborhood first to get things warm.
kg6mov is offline
You may not post new threads
You may not post replies
