front driveshaft - JeepForum.com
post #1 of 8 Old 12-01-2005, 12:22 AM Thread Starter
BradBurdett
front driveshaft
anyone know if there is a rebuild kit for a selec trac front drive shaft??
1995 ZJ 4X4
command-trac (NP231) with SYE
K&N FIPK intake
RE 6.5in lift with 33X12.5 BFG MT and no Rear Sway bar
4.56 gears--axle swap soon
BradBurdett is offline
post #2 of 8 Old 12-01-2005, 02:26 AM
guango88
Air Trans
guango88's Avatar
it all depends on what you want to rebuild, if its just the u-joints you could get those at any autoparts!
ONE ABOVE ALL
guango88 is offline
post #3 of 8 Old 12-01-2005, 12:13 PM Thread Starter
BradBurdett
its not the U-joints its the front part of the drive shaft that lets it extend, not sure what thats called
1995 ZJ 4X4
K&N FIPK intake
post #4 of 8 Old 12-01-2005, 04:04 PM Thread Starter
BradBurdett
^^^^bump^^^
1995 ZJ 4X4
K&N FIPK intake
post #5 of 8 Old 12-01-2005, 04:17 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Slip Yoke!
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #6 of 8 Old 12-01-2005, 04:18 PM Thread Starter
BradBurdett
yea is there a rebuild kit for the slip yoke???
1995 ZJ 4X4
K&N FIPK intake
post #7 of 8 Old 12-01-2005, 05:35 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Are you sure you have a slip yoke style front DS? In 95 there were three different types of front DS used. Two were U-jointed at the pinion and the other was the CV style "time bomb" (Hunter discribes it this way)
Of the two slip yoke style there was one with a metal slip-yoke dustcap (with a greasable fitting) and the other had a rubber boot around the slip yoke area.
Try quadratec for the rebuild kit or your local driveline shop
Why does it have to be rebuilt?
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #8 of 8 Old 12-01-2005, 07:05 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
At 6.5, I've only had mine redone after I bent the anticrombie out of it.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
front driveshaft lateralus3 ZJ Grand Cherokee Forum 8 12-19-2009 10:24 PM
front driveshaft normes ZJ Grand Cherokee Forum 2 08-01-2009 10:56 PM
Front driveshaft too long after swapping front differential jjeeeeppss ZJ Grand Cherokee Forum 11 08-12-2008 05:19 PM
Front Driveshaft GibsJeep ZJ Grand Cherokee Forum 8 01-02-2008 04:05 AM
Bad VC, can it be run without the front driveshaft? 93jeep93 ZJ Grand Cherokee Forum 5 01-11-2006 08:32 AM
