Front driveline vibes - JeepForum.com
post #1 of 5 Old 07-09-2009, 03:54 PM Thread Starter
ZJ_Richie
I have been getting light vibrations in the front just recently. I changed hubs & axle u joints previously so I knew it wasn't them. So I just removed the driveshaft and the u joints "look" ok but that isn't something to go off of. They are not tight or too loose. But the vibes are now gone.
So my question is since they are now gone can I rule out that it is not the pinion bearing, and rebuild the driveshaft?
Or is there another way I can see if it is the pinion bearing?
Thanks in advance.
3 in. Pro Comp lift with crawlerready 2 in. spacers, longer than stock control arms, front adj. track bar with IRO hd mount, rear adj. track bar, jks discos, Currie Currectlync, black soft 8's with 32 in. Hankook Dynapro mts
Future mods: hp30, 8.8 swap, IRO's 5.5 Critcal Path Kit
ZJ_Richie is offline
post #2 of 5 Old 07-09-2009, 03:56 PM
WhiteOut
WhiteOut's Avatar
Is there any way your driveshaft could be out, I would take it to a driveline shop and have them make sure its balanced and true.
WhiteOut is offline
post #3 of 5 Old 07-09-2009, 04:02 PM Thread Starter
ZJ_Richie
I was thinking that also, I might grab one at the jy this weekend. The place I go usually sells "little" items including driveshafts for between 5-10 bucks.
post #4 of 5 Old 07-11-2009, 01:06 PM Thread Starter
ZJ_Richie
After looking at the joints again I noticed some tight spots in the "ball" and middle u-joint. I bought the parts today and some paint and I am going to rebuild it.
post #5 of 5 Old 07-20-2009, 03:14 PM Thread Starter
ZJ_Richie
All fixed. The needle bearings in one of the caps of the center u joint were rusty as hell. All put back together and running fine.
Driveline vibes - stumped skain8 ZJ Grand Cherokee Forum 4 01-08-2011 07:33 PM
Driveline Vibes at 6" of lift nelson1248 ZJ Grand Cherokee Forum 30 07-16-2009 05:09 PM
Driveline Vibes nierace ZJ Grand Cherokee Forum 16 02-01-2007 06:21 PM
Driveline Vibes at 2in? 95JpGC ZJ Grand Cherokee Forum 2 04-21-2006 01:09 PM
