Front Drive shaft Problems..... Urghhhhhhh!
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
I recently install a 2.5" lift on my wj and have been getting some front drive
vibes at 30+mph.. Well... i was driving down the highway at about 50 mph and suddenly i hear something grinding and rubbing like crazy. So i pulled and looked and my front driveshaft was smoking near where i connects at the transfer case. Just changed the fluid with the correct NV247 fluid from Dealership. What would cause this? A Bad Front drive shaft??? Bearing??? btw 99 JGC, Quadradrive, CV front driveshaft
#2 |
Could be a bad cardon joint. That would be my bet.
#4 |
Yes!!! and that circle thing on the right side is the part that was getting too hot
#5 | |
![]() I also had irregular play in the DS when it was connected, check for that as well (a little rotational play is normal).
My 05 TJ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
