Front Drive Shaft Problem with lift kit - JeepForum.com
post #1 of 4 Old 09-12-2009, 12:27 AM Thread Starter
KDXFreestyle200
1994 Jeep Grand Cherokee Limited:
I just got this Jeep and it has a 4" Rock Krawler Lift Kit. (I believe it is 4", It has 33X12.5-15" wheels on it and they just fit. (They rub in the front at full turn.)) I went to the junk yard to get a stock front drive shaft out of a 94' because the one I have is about a half inch too short when fully extended. The bad news is that this shaft seems to be the stock one out of a 94'.
. . . . I was told there was a stock drive shaft previously in the vehicle, but am not 100% sure. I got the Jeep without the shaft in it. Also, BTW, This shaft comes out of the Jeep by the U-Joints with caps and bolts, No Yoke to pull out. I will cut and lengthen it with a custom machined sleeve if necasary. But, are there any fixes for this? Please help. Thanks, Jon
KDXFreestyle200 is offline
post #2 of 4 Old 09-12-2009, 12:36 AM
sandman
@ 4" a double cardan DS will be fine.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 4 Old 09-12-2009, 11:22 AM Thread Starter
KDXFreestyle200
Is there a driveshaft I can get from a junk yard out of another vehicle or something? A new drive shaft is somewhat out of my budget right now. If nobody knows a cheaper fix for this than buying new, it looks like I will be lengthening the stock shaft.
post #4 of 4 Old 09-12-2009, 08:28 PM
sandman
you dont need a longer shaft, what DS do you have now, is it the CV or double cardan DS? if its a CV the double caedan DS can be pulled from ZJs and XJs of most any year.
1993 Jeep ZJ. 4.0
sandman is offline
Stock single/double front drive shaft, 4.5" lift the88thpianoman ZJ Grand Cherokee Forum 14 10-30-2009 09:41 PM
distroyed cv front drive shaft after lift did I do somthing wrong sadass ZJ Grand Cherokee Forum 1 06-28-2008 07:04 PM
97 Grand Cherokee Problem with front Drive shaft Carlthree ZJ Grand Cherokee Forum 0 07-07-2007 09:11 PM
What Kind of Front Drive Shaft/Lift Kit ? Bosshound ZJ Grand Cherokee Forum 7 02-14-2005 11:43 PM
Drive shaft problem front diff info needed??? Kalisto2k1 ZJ Grand Cherokee Forum 3 01-25-2005 03:40 PM
