Front Drive shaft behind the CV - JeepForum.com
post #1 of 5 Old 04-01-2013, 07:55 AM Thread Starter
Mlarv
2014 JK Wrangler
joint there is a set of splines on the shaft that goes into the other side. There is a large nut on the TC case side of mine that is loose because I can turn it by hand. So should I be able to turn it by hand, what is it called, and is there a torque this should be torqued to?
96 zj 5.2 all wheel drive
Thanks
Mike
What Would Scooby Do?
Mlarv is offline
post #2 of 5 Old 04-01-2013, 08:05 AM
dnuccio
Post a picture of this
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 5 Old 04-01-2013, 08:07 AM Thread Starter
Mlarv
2014 JK Wrangler
I will have to wait till I get home from work to do this. I was just goofing off at work and thought of it. Thanks
Mlarv is offline
post #4 of 5 Old 04-01-2013, 10:14 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It keeps the plastic melt to lock retainer in place, just tighten it up.
Someone before you probably thought they could adjust the shaft, you can't.
ratmonkey is offline
post #5 of 5 Old 04-01-2013, 10:20 AM Thread Starter
Mlarv
2014 JK Wrangler
Thanks I was hoping it was a pretty simple thing.
Mlarv is offline
