-   -   Front Drive shaft behind the CV (http://www.jeepforum.com/forum/f13/front-drive-shaft-behind-cv-1502243/)
Mlarv 04-01-2013 08:55 AM
joint there is a set of splines on the shaft that goes into the other side. There is a large nut on the TC case side of mine that is loose because I can turn it by hand. So should I be able to turn it by hand, what is it called, and is there a torque this should be torqued to?
96 zj 5.2 all wheel drive
Thanks
Mike
dnuccio 04-01-2013 09:05 AM
Post a picture of this
Mlarv 04-01-2013 09:07 AM
I will have to wait till I get home from work to do this. I was just goofing off at work and thought of it. Thanks
ratmonkey 04-01-2013 11:14 AM
It keeps the plastic melt to lock retainer in place, just tighten it up.
Someone before you probably thought they could adjust the shaft, you can't.
Mlarv 04-01-2013 11:20 AM
Thanks I was hoping it was a pretty simple thing.
The time now is 06:44 PM.
