Front Differential repair cost - JeepForum.com
post #1 of 6 Old 09-25-2006, 12:41 AM Thread Starter
carpetking
Hi there, We just bought a used 2000 GC and after a couple days found that the front transfer case has a leak at the bearing point where the drive axle from the transmission attaches to it. We bought an aftermarket Service contract, but the way those things are worded, we don't know if it will cover the repair. Has anyone had this sort of problem in the past? If so, how much did it cost to have it repaired? We'd appreciate your thoughts! Thanks!
carpetking is offline
post #2 of 6 Old 09-25-2006, 12:31 PM
Double E
Double E's Avatar
It should be covered. However the sticking point of the contract that you have "prepared for" will probably also mention that regular service intervals are required to maintian the warranty.
If you have done this, you're all set. If not, be ready for them to claim that the issue was from your lack of "upkeep" or some other term that puts blame for part failure (& repair cost) on you.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 6 Old 12-05-2007, 03:23 AM
Briandl
He just bought it so what "upkeep" could he have missed?
If a service contract doesn't cover something as simple as that I'd be really worried, also why don't you mention this service contract in your other thread about your engine?
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #4 of 6 Old 12-05-2007, 01:43 PM
dickensheets
Is it the diff or tcase?
If it's the diff it's pretty easy plus a $10 seal. Lot's of info on here on how to do it. Or get a Haynes manual.
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #5 of 6 Old 12-05-2007, 01:54 PM
redhatman
redhatman's Avatar
Diff or Transfer case? The transfer case is in the center of the Jeep where both of the axles go out of, I am guessing its the diff. (The circular thing that leads to the wheels on both sides.) If its the differential, you may just be able to drain, clean, and reseal for about $15 by yourself. If its a bearing, a bit more. Either way, talk to them about it and make sure of the fine print. If you cannot get it repaired through them, take some pics.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #6 of 6 Old 12-05-2007, 04:40 PM
Jeeples
Jeeples's Avatar
Holy thread revival!
I'm thinking he probably got it fixed by now.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
Closed Thread
How Much Is The Repair Cost For Blend Doors? (Parts Only?) Briandl WJ Grand Cherokee Forum 8 03-22-2010 03:32 PM
01 wj Rear differential leaking. repair myself or pay someone else Royalty ZJ Grand Cherokee Forum 1 11-20-2008 05:52 PM
Front driveshaft too long after swapping front differential jjeeeeppss ZJ Grand Cherokee Forum 11 08-12-2008 06:19 PM
Stealership - Cost of Differential Fluid Change BigDamnNose ZJ Grand Cherokee Forum 12 10-19-2006 11:03 AM
Jeep died this week - Cost $500 to repair ;( MatrixRooster ZJ Grand Cherokee Forum 4 02-24-2003 08:44 AM
