Quantcast Front Differential Fluid Change - Really Necessary and How Often? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Front Differential Fluid Change - Really Necessary and How Often?
Brand new! XJ Rear DIY Bumper from JcrOffroad!Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 10-10-2008, 09:46 AM   #1
swataz
I was curious as to how essential changing your diff fluid really is, and if so, how often should this service be performed?
I have had my Jeep for a year now; it has about 104,000 miles and I have put about 8K on it since I 'inherited' it.
The diff fluid actually leaks a tad from the pinion seal, so I am wondering if maybe I need some extra fluid and if the original stuff has lost viscosity. No idea when or even if this service was ever performed.
Thanks guys and gals.
swataz is offline   Reply With Quote
Old 10-10-2008, 09:56 AM   #2
QuadraTokn
1930 WJ
every 30k miles.
I have to change mine every oil change though. even after i rebuilt them, they look really dirty after a short amount of time.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 10-10-2008, 10:20 AM   #3
ratmonkey
Living dead mod
ratmonkey's Avatar
i'd do it once a year if you're up to the service yourself. otherwise i believe it's recommended at somewhere around 20k for jeeps.
i seem to change mine out about every motor oil change on average because of some other service i happend to need to perform.
ratmonkey is offline   Reply With Quote
Old 10-10-2008, 12:57 PM   #4
DavidMoses
Its it easy to do it yourself?
DavidMoses is offline   Reply With Quote
Old 10-10-2008, 02:15 PM   #5
GCDenver
I just did my front last Friday night for the first time. Here are a couple useful write-ups
http://www.4x4xplor.com/diff-service.html
http://www.stu-offroad.com/misc/diff-1.htm
I ended up using a wire wheel on the end of a drill to get the old RTV off, not sure if that is recommended ?, it did leave some scratch marks but no gouges, I also used a plastic putty knife and a razor blade, but the wire wheel worked well. I got a LubeLocker dana 30 gasket so I didn't have to mess with RTV. when I do the rear I will have to use RTV since there is no LubeLocker for a Dana 44A. I would also definitely recommend a $5 transfer pump from an auto parts store to fit on the gear lube quart bottle, I got mine at Checker, makes it much easier to re-fill the Diff.
GCDenver is offline   Reply With Quote
Old 10-10-2008, 05:50 PM   #6
swataz
Thanks guys....here is a follow-up question...is there any audible signal of a 'sub-lubed' diff when your foot is on the accelerator?
Old 10-10-2008, 11:00 PM   #7
GCDenver
Not sure about an audible sound, except for axle chatter if you have Limited slip axles which require Friction Modifier and you don't have enough in the Diff or have a gear lube which doesn't have FM already in it. I have no idea what axle chatter sounds like and I hope I never hear it
Do a search on Friction Modifier or FM and there will be some threads about Differential noise.
Old 10-11-2008, 05:48 AM   #8
ratmonkey
Living dead mod
ratmonkey's Avatar
noises generally appear in the diffs after damage has already occured.. on acceleration is usually a pinion bearing or excessive wear on the powered side of the gears.
Old 12-07-2008, 11:13 PM   #9
ephjeep
Diff Fluid Change
I have a WJ with Quadradrive and 76K miles. I studied the forum for a while to help address weird noises coming from my axle(s). I went with synthetic fluid with friction modifier from Chrysler. Noises went away. Also changed engine oil and TC fluid (with Chrysler product at $13 per qt.). There was less than a qt. in there when I drained it. I don't think it was touched by the PO in 75K miles. Good logic for buying a car new!!
ephjeep is offline   Reply With Quote
Old 12-07-2008, 11:55 PM   #10
Kruzin
ANY component that uses lubricant is essential to change at some point. Viscosity in lubricants breaks down over time.
Axle lube should be done about every 20-30k.
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Old 12-08-2008, 12:05 AM   #11
xJoshxx
xJoshxx's Avatar
2011 WK
i believe if you get amsoil gear lube it has Modifiers i think?
amma right Gabe?
xJoshxx is online now   Reply With Quote
Old 12-08-2008, 12:09 AM   #12
xJoshxx
xJoshxx's Avatar
2011 WK
double post.
Old 12-08-2008, 12:44 AM   #13
the88thpianoman
Luck favors the prepared
the88thpianoman's Avatar
2003 WJ
amma right Gabe?
Yep, amsoil severe gear includes the friction modifier.
the88thpianoman is offline   Reply With Quote
Old 12-08-2008, 01:08 AM   #14
GrimJeeper91
A good indicator is to pull your front plug and take a look at the oil that's in there and the end of the plug since it's magnetized. One look at mine and it was clear that it was time for a change.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote
Old 12-08-2008, 07:20 AM   #15
swataz
When I pulled my plug, the goop on the end of it looked like grease. The fluid itself when I poked a finger in there didn't look TOO bad, and the level was pretty good, maybe a tad low. I topped it off.
I have a high pitched buzzing sound occurring for a week now and I cannot seem to ascertain where it emanates. Seems to disappear at about 15-20 MPH when decelerating and doesn't happen all the time. I am getting the feeling that is it is my axle though. Wish I could record the sound and post it!!!
Glock Forum
