front diff problems - JeepForum.com
post #1 of 6 Old 01-01-2004, 08:37 PM Thread Starter
tvillejeep
front diff problems
new here and was wondering if there any proned problems the the front diff in a all wheel drive model. the roaring sound is more noticable under deceleration than under pull. differential problems are about the only thing that i have no clue about. thanks for any info.
tvillejeep is offline
post #2 of 6 Old 01-01-2004, 09:08 PM
JAURS
I'm starting to get the same roar/growl in my front end with my ZJ. I believe I have the Dana 35 in the front and the 44 in the rear. I have the all wheel drive NP249 transfer case also. I have a suspension lift, so maybe I'm hearing noises related to that. Hopefully someone more educated on differentials can shed some light on this issue.
1996 Grand Cherokee Ltd.
5.2 V8
3" Skyjacker lift
2004 Jeep Liberty Renegade (stock for awhile)
Pics:
http://community.webshots.com/scripts/show.fcgi?t=slideshow&ID=108993811&key=VTeyLQ
http://www.imagestation.com/album/?id=4288067675
JAURS is offline
post #3 of 6 Old 01-02-2004, 02:49 AM
RockPaws
RockPaws's Avatar
The ZJ's came with Dana 30 front differential, The rear came with either the Dana 35 or 44, The 44 model was different than others, in that it had an aluminum center section.
It sounds like you both need new bearings installed in the differentials. Most likely its the carrier bearings. They seam to have been a problem. I have found 3 ZJ that I have worked on with bad bearings. One had the front diff and two the rear carrier bearings go out. One was my personal ZJ.
A stethoscope can be used to pin point which bearing is making the noise. and verify if it is the differential. Also check the gear oil for metal particles. If metal is found in the gear oil, make sure all bearings are replaced. The whole differential must be cleaned completely. I have spent 2 hours cleaning the axle tubes due to metal found. They are cleaned like a rifle bore. Its lots of work, but worth it. If they are not cleaned the metal will work its way into the new bearings. Causing more problems.
One problem area I have found is the carrier bearing preload from the factory was set too tight. The preload should be about .012, ( it was at least .020 or more from factory).
Frank
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #4 of 6 Old 01-02-2004, 10:53 AM
DrewT
It may be that your VC is going bad...unless you live in an area that snows alot, it may be cheaper to replace it with the 242 TC, since there is no VC to go out, and it can go into 2WD
-Drew
DrewT is offline
post #5 of 6 Old 01-02-2004, 11:33 AM
JAURS
I don't think my VC is going bad because around tight turns, like in the parking lot, I don't get binding or squealing from the tires. Hopefully I don't have a bearing starting to go, but if it was, is there any harm in not doing anything immediately? The noise has been there for the past 4-5K miles, basically a little after putting in my lift. It has not gotten worse, just stayed basically the same. Thanks.
5.2 V8
3" Skyjacker lift
Pics:
JAURS is offline
post #6 of 6 Old 01-04-2004, 05:40 PM Thread Starter
tvillejeep
is there any chance that i might have be having spider gear problems. i took wheels calipers and rotors off the front and when i would turn the axle by hand i can hear teeth hitting together in the diff as well as feel it through the axle?
diff problems SoCalDevyn ZJ Grand Cherokee Forum 4 01-19-2010 11:50 PM
'06 QDII - Front Diff problems DuneCrawler WK Grand Cherokee & XK Commander Forum 1 12-24-2009 08:29 AM
diff problems and need some help lothar863 ZJ Grand Cherokee Forum 16 02-11-2008 07:49 AM
Bearing/Diff. problems! Hope its only that... rdm395 ZJ Grand Cherokee Forum 1 12-20-2005 11:24 PM
Must be the week for front diff problems JBasham ZJ Grand Cherokee Forum 1 03-11-2002 05:00 PM
