front diff. problems? - JeepForum.com
post #1 of 4 Old 05-03-2013, 07:17 PM Thread Starter
EYPUFF
EYPUFF's Avatar
hey guys..
so if you guys look at last thread you'll see that i changed my axle shaft recently.. and it was not as painless as i had hoped..
the reason i changed my axle shaft was because i was starting to hear a slight grinding-like noise along with what i can only explain as shuddering metal? and i hoped that the axle shaft i've been neglecting to change was the source of that awful noise. and turns out.. it wasn't..
so since it was time to change the diff. fluid i went ahead and started to take the cover off and didn't find anything out of the ordinary.. except i saw that there was a lot of play in the gears.
when i had the front end up in the air.. i was able to move my wheels from the 12 o'clock position to about 1 o'clock and going backwards to the 11 o'clock position. is my front end on its way out? what do i need to check/fix/change/replace?
any insights would be much appreciated.. thanks for your help!!
1995 GC 5.2 Limited V8
Green Jeep Club Member # 32
EYPUFF is offline
post #2 of 4 Old 05-03-2013, 07:30 PM Thread Starter
EYPUFF
EYPUFF's Avatar
so after some more reading.. i'm thinking this is not something i want to tackle in the garage w/o a lift.
reference:
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
http://www.jeepforum.com/forum/f13/c...build-1344601/
EYPUFF is offline
post #3 of 4 Old 05-04-2013, 05:07 AM
speedbucket
I would guess unit bearings before ring and pinion. Mine moves a lot more than that but I have 270k miles on my front gear setup. Get it up in the air and figure out where the noise is coming from
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 4 Old 05-05-2013, 10:52 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
rotating the wheels back and forth doesn't tell you too much about the condition of the ring and pinion.
check for side to side play of the ring gear and carrier, hold the PINION yoke steady and check the rotational play of the ring gear(backlash), you'll need a dial indicator for that.
check for movement of the pinion in the bearings.
ratmonkey is offline
