Front Diff Breather Hose torn off '94 grand cherokee 5.2 V8 - JeepForum.com
post #1 of 104 Old 06-24-2008, 11:28 AM Thread Starter
BFI
1994 ZJ
Ive been getting a clunking noise in sharp turns, a whining noise at speed and horrible propane like smell coming from the front end.
I looked around and seen a hose hanging down, I believe this is the breather/overflow hose for the front diff, it is firmly attached to the front difft but the other end looks sheered off and it doesnt appear to reach anything else, would this cause all the above problems?
Where is this hose supposed to go? Engine? Transmission? Radiator? I cant tell where its supposed to go and it doesnt appear to reach anything, so Im assuming it blew off and got torn in half whilst driving or something.
Would this also cause the diff oil to drain out? Are the transmission and Diff fluids seperate? Does this mean I need to refill the diff fluid?
Thanks for any help
BFI is offline
post #2 of 104 Old 06-24-2008, 11:35 AM
JCZJ
All breather hoses attach to one thing and are used as a vent, allowing whatever they are connected to to breathe. It should be secured up as high as it can be.
1998 ZJ // 5.2L // Lifted!
1994 ZJ // 4.0L // 271,000 miles // Some cool stuff // RIP 5/25/08
1965 Ford Mustang 2+2 // Boss 302 Swapped // Locked 9" rear
Originally Posted by Shoey40 View Post
She can XJ my WJ whenever and however she wants. Hell, I'd let her CJ it, too.
JCZJ is offline
post #3 of 104 Old 06-24-2008, 11:54 AM Thread Starter
BFI
1994 ZJ
Theres no visible places any hose would connect anywhere around the air intake or engine, I cant see another end of a hose at all, Theres so much stuff in this engine bay I cant tell a damn thing, Can you give me a specific place to look? front of the engine near the alternator? or at the back near the firewall? top of the engine or bottom? etc
There is oil dripping out the end of this hose also
Thanks
BFI is offline
post #4 of 104 Old 06-24-2008, 11:55 AM
sou812
yes this hose is important! its a vent hose. it goes form the diff to a point up on the vehicle as high as the top of the radiator to keep water out. so repair that and service the diff and repair any leaks. that is about all i can tell you!! but let me know how every thing works out..
sou812 is offline
post #5 of 104 Old 06-24-2008, 12:12 PM
JCZJ
Again, the hose doesn't connect anywhere. It just needs to be secured as high as possible in the engine bay.
JCZJ is offline
post #6 of 104 Old 06-24-2008, 12:16 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
You should try replacing the fluid in your axle also...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #7 of 104 Old 06-24-2008, 12:17 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Okay,
did you affix it to anything yet, you can use a zip tie.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 104 Old 06-24-2008, 12:57 PM
Windowsrookie
The front Differential breather tube attaches to the side of the air box.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #9 of 104 Old 06-24-2008, 01:18 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I had that hose fall down and wrap around the front driveshaft, taking out the front pinion seal in the process. To add insult to injury, my inlaws were in the back seat when it happened.
HighLonesome is online now
post #10 of 104 Old 06-24-2008, 02:13 PM
Virmagicus
Virmagicus's Avatar
Funny stuff right there.
Jeff
Virmagicus is offline
post #11 of 104 Old 06-24-2008, 04:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
to clarify slightly, is clips to it but doesn't run into it.
ratmonkey is offline
post #12 of 104 Old 06-24-2008, 04:24 PM Thread Starter
BFI
1994 ZJ
So its just an open ended tube? how does it work? i zip tied it to a bracket however i dont believe it will stay like that for long, it has to have gotten shredded because its not long enough to get very far.
BFI is offline
post #13 of 104 Old 06-24-2008, 04:58 PM Thread Starter
BFI
1994 ZJ
Ive looked at the side of the air box, I dont see anything where it could clip to, so i guess the mounting and the clip must have gone too. Ive got it booked in at a garage tomorrow so Ill get back to ya'll with the diagnosis.
Thanks for the Help
BFI is offline
post #14 of 104 Old 06-24-2008, 07:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's a vent tube to allow air to escape or return into the front diff, all you need to do is run it to a high enough place that water won't get to it. it doesn't plug into anything on the top end. and it either clips to the side of the air box or theres a clip on the inner fender for it. if nothing's there just zip tie it as high up as you can.
propane smell is an odd one, could be your cat going bad, though that's just a stab in the dark.
clunking could be bad cv joints in your axles since it's only in sharp turns, torn boots are usually a good sign that they're bad or going bad soon.
whining could be the pinion bearing, bad gear mesh in the ring and pinion or spider gears, bad carrier bearings, bad wheel bearings. without narrowing down where the sound is coming from and getting into it to look it's hard to diagnose over the internet.
post #15 of 104 Old 06-24-2008, 09:29 PM
UTChavok
yeah my breather tube for the rear diff came off wherever it normally is secured to when I was doing the lift, I ziptied it up to one of the fuel lines and now I hear a whining noise when Im moving. Im guessing this is the cause? Didnt think that much noise could come out of that little tube.
-Ronnie
UTChavok is offline
2006 Grand Cherokee Front Diff HEMIX2 WK Grand Cherokee & XK Commander Forum 6 06-26-2008 01:51 PM
2006 Grand Cherokee Front Diff HEMIX2 WK Grand Cherokee & XK Commander Forum 0 06-25-2008 02:34 PM
Howling front diff 97 Grand Cherokee Lorado. 92jeepyj ZJ Grand Cherokee Forum 11 03-12-2008 06:45 PM
2005 Grand Cherokee front diff leaking klaymon ZJ Grand Cherokee Forum 3 09-22-2005 10:25 AM
front Diff Hose mikerob159 ZJ Grand Cherokee Forum 3 09-18-2005 05:57 PM
