Front dif. locked out all the time - JeepForum.com
post #1 of 5 Old 10-05-2003, 03:49 PM Thread Starter
Trevor Khoury
I just purchaced a 1993 grand cherokee with the 5.2 motor in it and I am having problems with it when I make sharp turns. When I am turning it is very choppy like the front dif. is locked, the outside wheel leaves rubber on the ground and I don't know why it is doing this. Does anyone have any suggestion as to what is wrong, I don't know much about the grand cheokee?
Thanks for your help
Trevor
Trevor Khoury is offline
post #2 of 5 Old 10-05-2003, 05:57 PM
boing
Trevor
Your Viscious Coupling is gone and will need to be replaced it is not a cheap repair over $1000 You would be better off swaping the 249 transfer case out for a 242 it will cost about the same price if not cheaper than fixing the VC in the 249 and you get a better transfer case. Also for more info just do a search on viscious coupling you will have alot of reading. My VC went out on my ZJ just after I bought it but I was lucky the dealer went good for the repair. And if I Knew then what I know now I would have got them to swap a 242.
boing
boing is offline
post #3 of 5 Old 10-06-2003, 02:06 PM
Harald
boing
Boing
Got a 96 GCL 5.2L, any idea of what milage to expect from the VC? Got a symptom that probably is rear diff. limited slip, but also could be the VC.
Harald
Harald is offline
post #4 of 5 Old 10-06-2003, 02:24 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'm still on my original VC. (147K) It truly depends on how the vehicle is driven. I know a lot of Grands that are punished by purely being street driven.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 5 Old 10-06-2003, 02:53 PM
boing
I think its a gambel you pay your money and take your chances. but a little preventive maintance like rotating tiers and checking the tire pressure regularly.
Boing
boing is offline
Front Hubs (?) sound locked when coming to a stop Jagillac ZJ Grand Cherokee Forum 2 12-29-2008 12:50 PM
front diff locked up....need help...... DEEPERTHEBETTER ZJ Grand Cherokee Forum 1 10-22-2008 12:13 AM
Front brakes locked on mcnultyj ZJ Grand Cherokee Forum 4 05-15-2008 05:29 AM
98 ZJ w/locked up 249 TC: Going to remove front driveshaft shudog ZJ Grand Cherokee Forum 10 04-15-2007 08:08 PM
Front End Fix Up Time micifus ZJ Grand Cherokee Forum 17 03-15-2007 08:41 AM
