Front CV joint stuck to diff. - JeepForum.com
post #1 of 6 Old 08-23-2011, 07:07 PM Thread Starter
jaguarjoe
Title sez it all. I took the six bolts out and took the TC end off the DS. Now the CV joint is stuck in the yoke. I have a huge pair of 460 Channelocks that can grab it but it won't budge. I tried tapping it off with a large screwdriver and hammer but it won't budge.
Any ideas?
jaguarjoe is offline
post #2 of 6 Old 08-23-2011, 07:54 PM
savannahzj
my 98 had six bolts on each side of the front drive shaft. the yoke stays in the diff.
savannahzj is offline
post #3 of 6 Old 08-23-2011, 10:35 PM Thread Starter
jaguarjoe
The yoke is attached to the diff with the big pinion nut, right? Don't wanna take that off because it wrecks the preload.
There is nothing else holding the CV joint to that yoke besides the 6 8mm bolts, right? I sure can't see anything.
There's nothing under the CV boot to hold it on is there? That would be dumb.
post #4 of 6 Old 08-23-2011, 10:40 PM
DoozerPeej
It just gets stuck in there, hit the side of the joint pretty good with a dead blow hammer or put a piece of wood on it and hit it with a regular hammer. It will come loose eventually if the bolts are all out.
DoozerPeej is offline
post #5 of 6 Old 08-24-2011, 12:08 PM
savannahzj
Remove the 6 bolts, tap with hammer, it should come out. Mine practically fell out once all the bolts were removed.
post #6 of 6 Old 08-24-2011, 12:21 PM
speedbucket
you not on a hill where the driveshaft is in a bind are you? try rocking the tires back in forth with you hand
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
Front Diff Stuck mpzj ZJ Grand Cherokee Forum 9 11-20-2010 02:09 PM
Roaring rear (diff, bearing, u-joint, etc?) xmonger ZJ Grand Cherokee Forum 2 09-08-2010 05:16 PM
Rear Diff Upper Ball Joint Support KBSkye ZJ Grand Cherokee Forum 7 03-02-2010 09:55 AM
diff or hubs stuck in 4wd? help schu98ZJ ZJ Grand Cherokee Forum 12 04-28-2008 07:18 AM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 02:48 AM
