Front Calipers "Teves" or "Akebono"?
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
Hi All,
I need to replace my front calipers (2nd time, only 85K). Napa auto parts asked if I need the “Teves” or “Akebono”. I have no clue and I was not asked this question the last time I replaced the calipers. Does anyone know what I should order? Engine: 4.7L AC Quadra Drive Automatic Thanks in advance, Jim
#2 |
Living dead mod
akebono is the updated part for grands, the teves caused warped rotors constantly.
'97 zj 5.2, some stuff, some other suff, and some things that even work sometimes. |
#3 |
OK, so either one will fit, but the Akebono is the ideal way to go.
One day my vehicle would pull to the left when I applied the brakes and I smelled this odor of burning metal. The next day I had no brake problems at all. Does this indicate a caliper that is failing and should be replaced? Should I try WD-40, would this help? |
#4 |
Switch to the akebonos. I bought new stillen rotors and pads last year and they're already warped, not even 5k miles later.
#5 |
Akebono is by far the better caliper don't get the teves
2000 WJ Laredo 4.7L: K&N CAI, Gibson cat-back, Superchips tuner, 37x12.5x16.5 Goodyear MT's on U.S. Wheel steelies w/ Spidertrax spacers, spooled D44 front w/ mechanically actuated CAD, modified Tom Woods DS, Ballistic Fabrication steering kit, D44a Aussie locked w/ 4.10's, IRO rock sliders, IRO T-case skid, IRO 4" w/ HCLA, , Hella 4000's, Warn front 2" receiver, Superwinch LP8500 w/ receiver mounting plate, interior roll cage, Corbeau Baja Ultras w/ 4-point harnesses... 1992 YJ 4.0L (Still in pieces): AX15 w/ Centerforce clutch kit, Dana 300 twin-sticked, Fabtech HC Bellypan, Pass-Drop HP44, Ford 9" (35 spline spool, 35 spline Yukon 1540 shafts, Ballistic Fabrication pinion guard), 5.13 Yukon gears, 3-link front w/ Rancho RS9000XL coilovers, 4-link coil sprung rear 2011 Ram 1500 Big Horn 5.7L (The DD/tow rig): K&N CAI, Weather Guard low-pro saddle box, Viair constant duty compressor system "BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner |
#6 |
Yea Kolak Hooked me up BIG BIG time Bought the Caliper Upgrade he has 2x Full loaded pairs with brackets and everything and stillen pads and rotors ZOMG it cured my Highspeed Brake DW
teve's Design is Super poor the pads are connected to the caliper. <--Old school Akebono's Have a bracket Which the pad sits then the caliper fits over top of them 100x better design and the Slid Pins are 1000000000000x^10000000000000000000 Better than teve's horrible Horrbile. No akebono's will NOT NOT fit on a teve's Bracket you need a Akebono bracket.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs 2011 WK2 Laredo with ORA1 |
#7 |
Im new here i have a question I have to replace my brake pads im not sure which ones i have my grand cherokee laredo is a 2000 and i was told at one point if it had the clips or no clips. mine has the clips do i have Teves thanks.
#8 |
Are your calipers silver or black? That's what someone selling pads asked me. That's how you can tell.
-Tom 2001 Grand Cherokee Limited 2002 BMW 530i |
#9 |
TEve's also HAS A HUGE Metal Wire running on it. Akebono doesnt
#10 |
Hi my calipers look more like dark brown and i have a big silver clip on the caliper they look similar to a rear drum brake spring. I am assuming they are teves. Also Do i have to buy factory rotors and pads? I had the brakes done about 2 years ago and i purchased from the factory. But I feel im just wasting money when i can buy a good set of aftermarkets. I owned over 20 cars and always bought aftermarket replacement with no problems before. Any reason that everyone says you have to buy factory. thanks
#11 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
