front caliber Q - JeepForum.com
post #1 of 5 Old 08-24-2011, 08:15 PM Thread Starter
Darman
front caliber Q
Front CALIPER Q not caliber
ok so im installing new calipers, ceramic brake pads and rotors and i took my old calipers off and hooked the new ones up to the banjo joint only it leaks. i did the banjo joint hand tight and it still leaks. do i need to line the holes up in the bolt with the banjo joint or do i need to tighten it more or maybe some rust or something in the way? can i use some sort of sealant on them to stop the leaking?
Darman is offline
post #2 of 5 Old 08-25-2011, 03:31 AM
mudruna
1994 ZJ
did you put both of the copper washers on the banjo bolt? there should have been 2 new ones supplied with you calipers, if not NAPA has them. even if you used the old ones it may leak, make sure you have one on each side of the banjo fitting, one between the caliper and banjo and one between the banjo and the bolt.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline
post #3 of 5 Old 08-25-2011, 04:09 AM
Mark05059
this and make sure that the bolt is tight... remember your crushing the copper washers to make a seal
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 5 Old 08-25-2011, 07:19 AM
Technohead
Originally Posted by Darman View Post
. . . i did the banjo joint hand tight and it still leaks. . .
This might be the problem.
-Eric
Technohead is offline
post #5 of 5 Old 08-25-2011, 10:08 AM Thread Starter
Darman
i didnt use the washers. i thought they were for the bolts to attach it to the knuckle. thanks alot, hopefully that will fix my problem
Darman is offline
Front to Rear swap...can't I just steal front springs? allenjp ZJ Grand Cherokee Forum 12 02-08-2009 04:54 PM
front noise after removing front skid plate davets ZJ Grand Cherokee Forum 2 12-08-2008 05:54 AM
Brake Caliber Position? adgjqetuo ZJ Grand Cherokee Forum 2 05-01-2008 09:09 AM
Vibration in Front End Possibly Front drive shaft??? CrazyDrivinJoe ZJ Grand Cherokee Forum 4 11-21-2007 04:56 PM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 02:48 AM
