#1 | |
Front bumper mount template
Hi folks! I normally hang out over in the XJ area so please pardon my ignorance.
I'm trying to find a template for a ZJ front bumper mounts to compare to an XJ template to see if a bumper that I'm building can be easily adapted to a ZJ. Yeah I tried the FAQ's and did a search with multiple keywords, but no luck at all. Anyone able help?
Spec's |
#2 |
You could search google for a front mounted hitch and find the install instructions, it will show the mounting points you can use.
No measurements.. But you can see how it mounts.. http://www.hiddenhitch.com/fitguides/pdf/N65008.pdf
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
#3 |
Thanks, but what I really need is template that shows the mount dimesions and bolt hole locations.
I don't have a ZJ available for determining the dimensions so a picture just won't work.
Spec's |
#4 |
would a template for that factory skid plate be of any use to you? I am not sure but I think it bolts the same place that a hitch would bolt. I am not sure how a new front bumper bolts on either. I just took mine off and its laying here, also I could give other dimensions if I knew what you might looking for. GC is sitting here in my garage and i'm tinking on stuff.
#6 |
Frank, if you need to spend some time around some ZJ's just let me know!
95 ZJ with stuff |
#7 |
Yes I found out that will not help you any. But if you want to build an extra bumper and send it to me I will try in on to see if it fits. And if it fits will post right away a big thankyou
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
