Front brake pulsations - Page 2 - JeepForum.com
post #16 of 17 Old 08-23-2009, 12:54 PM
McGR
2007 XK Commander
I've just come to accept that I will need to work on the front brakes on an annual basis. I've lost count of the amount of brake jobs I've done on the fronts on my '99. Probably 7 or 8 now. I'll usually cut or replace the rotors and replace the pads if needed. Once I do this, I'm good for another 15-20K. I do the work myself and the cost of new parts is fairly low. I can live with it...
McGR is offline
post #17 of 17 Old 08-23-2009, 05:56 PM
indept
When you replace the rotors, wire brush all the rust off of the hub where the rotor mates to it. Also clean the mounting face of the rotor if you're putting the old one back on. You should also check the rotor for runout. Excessive runout can cause warping too. Runout should be no more than a few mils max.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
Front brake job, what tools? Mickey_D ZJ Grand Cherokee Forum 9 09-20-2008 03:25 AM
Front brake pad change on a '05 4wd? SoCal Rebell WK Grand Cherokee & XK Commander Forum 3 06-20-2007 07:08 PM
Front brake rotors israelshapiro ZJ Grand Cherokee Forum 4 04-19-2006 05:21 AM
94 GC front brake question GST97 ZJ Grand Cherokee Forum 1 08-25-2005 10:51 PM
Front Brake Rotors theandies ZJ Grand Cherokee Forum 2 06-28-2004 01:06 PM
