Front brake caliper thread repair - JeepForum.com
post #1 of 7 Old 05-22-2007, 07:36 PM Thread Starter
Stuart
2005 KJ Liberty
I stripped out one of the bolt holes for the front brake calipers on my 98 GC, the caliper bolt size is 8mm x 1.25mm but I'm having trouble locating a helicoil kit in that size, anyone have any sugestions?
1998 Grand Cherokee Laredo
with a 5.2 It's All stock
and all RED
Stuart is offline
post #2 of 7 Old 05-22-2007, 07:57 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Looked at auto part stores? There is a thread on this EXACT issue on the first page of the forum where a poster broke off the bolt extractor I believe and replaced the calipers for dirt cheap. May be your best option anyways
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 7 Old 05-22-2007, 08:02 PM
-Joe-
-Joe-'s Avatar
I believe he is talking about the caliper mounting bolts. Which bolt into the knuckle..
Ace hardware or a normal hardware seems to carry more of those then the autopart stores for some reason.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 7 Old 05-22-2007, 08:06 PM
ArloGuthroJeep
Mr. Hyde!
8mm? WJ's run 18mm for those bolts...silly tiny ZJ's
post #5 of 7 Old 05-22-2007, 08:54 PM
TJeeper
TJeeper's Avatar
ZJs use sliders built into the knuckle to mount the calipers. The bolts position the calipers on the rotors. Dumb design, but you should know what you are talking about before you make stupid remarks.
Patrick
TJeeper is offline
post #6 of 7 Old 05-22-2007, 08:56 PM
TJeeper
TJeeper's Avatar
I'm told NAPA sells the appropriate helicoil. A local Jeeper just made the same mistake. The torque value on that bolt is 11ft/lbs.
Patrick
TJeeper is offline
post #7 of 7 Old 05-22-2007, 10:40 PM Thread Starter
Stuart
2005 KJ Liberty
I'll check with napa, I did a dumb thing and stripped it out, didn't use a torque wrench like I should have, and yes, it's 8mm x 1.25mm small caliper mounting bolt that runs through the slider into the knuckle, pretty small bolt, but that is the size, double checked it with a tap and die set, that's how I came up with the 8 x 1.25
I just replaced the front hub bearings and striped it out when I put it back together, found the hub bearings on ebay for $43 each, new in the box, so I did both sides even though it was only the drivers side that was bad, and that axel nut is a real bear to get off, finally got it after breaking two breaker bars and an impact wrench
and all RED
Stuart is offline
Front brake caliper slide seized greggersWJ ZJ Grand Cherokee Forum 10 08-12-2008 12:26 PM
Front brake caliper wont go back on nosewitdot ZJ Grand Cherokee Forum 1 05-12-2007 11:01 PM
Front Brake Caliper Bolt Hole Strippage freakydiver ZJ Grand Cherokee Forum 11 10-18-2006 09:49 AM
'99 Front Brake Caliper Upgrade JeepMax ZJ Grand Cherokee Forum 18 06-21-2006 05:25 PM
Can't get the front brake caliper holder off McCarley ZJ Grand Cherokee Forum 3 05-29-2006 07:09 PM
