Front ball joints replacement!!!! Help - JeepForum.com
post #1 of 12 Old 07-21-2013, 07:28 PM Thread Starter
accord23
How hard is it to replace Front Ball joints? do they need any special tool? do they need to be Machine Pressed? is this something that unexperienced somebody like me can do? or i need to take it to the shop?
accord23 is offline
post #2 of 12 Old 07-21-2013, 07:30 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Don't use too many exclamation points or question marks. Makes you look like a clown. Especially when you haven't searched.
HighLonesome is online now
post #3 of 12 Old 07-21-2013, 07:32 PM Thread Starter
accord23
Thanks HighLonesome....that really helped me fix my Ball joints....
accord23 is offline
post #4 of 12 Old 07-21-2013, 07:36 PM
sxi4evr
just go to autozone and rent a ball joint press... that's all you need
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline
post #5 of 12 Old 07-21-2013, 07:43 PM
JasonStebbins
Do you have a decent set of tools? It's really not that hard to do. You rent a ball joint press at any parts store to do it.
Remove axle nut
Remove tire
Remove rotor/caliper
Remove tie rod
Remove wheel bearing hub/axle
Use BFH to pound off knuckle
Use press to remove/install ball joints
It takes a few hours if it's your first time. A shop will charge you a few hundred dollars easy.
Poop
JasonStebbins is offline
post #6 of 12 Old 07-21-2013, 08:50 PM Thread Starter
accord23
Thank you all.
accord23 is offline
post #7 of 12 Old 07-22-2013, 04:40 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
http://www.jeepforum.com/forum/f13/c...36/index2.html
This might help you a bit if you have never done it.
Originally Posted by HighLonesome
coralman is online now
post #8 of 12 Old 07-22-2013, 04:59 AM
Technohead
Be very careful if the rented press does not have adapters specifically designed for Jeep axles (and most don't) or else you can easily press them in at an angle and ruin the outer axle C.
-Eric
Technohead is offline
post #9 of 12 Old 07-22-2013, 05:26 AM
AVR2
There are Jeep balljoint replacement videos on YT where they've used washers as shims to replicate the angled adapter. That could be a solution. Personally, I just ponied up to buy a proper adapter kit.
AVR2 is offline
post #10 of 12 Old 07-22-2013, 05:33 AM
bigbill888
Take it to the shop
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #11 of 12 Old 07-22-2013, 05:33 AM
JeepNicholson
Remove axle nut
Remove tire
Remove tie rod
You don't even have to remove the tie rod end if you're careful and prop up the steering knuckle so it doesn't fall down
JeepNicholson is offline
post #12 of 12 Old 07-22-2013, 01:26 PM
gomes512
1994 ZJ
Did mine last month with the Autozone balljoint press. They did not have the one with the angled adaptors for Jeeps. I used a piece of old fence post that I cut up into various angled pieces with a sawzall and used the one that worked best.
Without the angled adapters the job is a pain, the adapters make it much easier.
gomes512 is offline
