-   -   Front ball joints replacement!!!! Help (http://www.jeepforum.com/forum/f13/front-ball-joints-replacement-help-1551941/)
accord23 07-21-2013 07:28 PM
How hard is it to replace Front Ball joints? do they need any special tool? do they need to be Machine Pressed? is this something that unexperienced somebody like me can do? or i need to take it to the shop?
HighLonesome 07-21-2013 07:30 PM
Don't use too many exclamation points or question marks. Makes you look like a clown. Especially when you haven't searched. :rofl::rofl::rofl:
accord23 07-21-2013 07:32 PM
Thanks HighLonesome....that really helped me fix my Ball joints....
sxi4evr 07-21-2013 07:36 PM
just go to autozone and rent a ball joint press... that's all you need
JasonStebbins 07-21-2013 07:43 PM
Do you have a decent set of tools? It's really not that hard to do. You rent a ball joint press at any parts store to do it.
Remove axle nut
Remove tire
Remove rotor/caliper
Remove tie rod
Remove wheel bearing hub/axle
Use BFH to pound off knuckle
Use press to remove/install ball joints
It takes a few hours if it's your first time. A shop will charge you a few hundred dollars easy.
accord23 07-21-2013 08:50 PM
Thank you all.
coralman 07-22-2013 04:40 AM
http://www.jeepforum.com/forum/f13/c...36/index2.html
This might help you a bit if you have never done it.
Technohead 07-22-2013 04:59 AM
Be very careful if the rented press does not have adapters specifically designed for Jeep axles (and most don't) or else you can easily press them in at an angle and ruin the outer axle C.
AVR2 07-22-2013 05:26 AM
30 Attachment(s)
There are Jeep balljoint replacement videos on YT where they've used washers as shims to replicate the angled adapter. That could be a solution. Personally, I just ponied up to buy a proper adapter kit.
bigbill888 07-22-2013 05:33 AM
Take it to the shop
JeepNicholson 07-22-2013 05:33 AM
Remove axle nut
Remove tire
Remove tie rod
You don't even have to remove the tie rod end if you're careful and prop up the steering knuckle so it doesn't fall down
gomes512 07-22-2013 01:26 PM
Did mine last month with the Autozone balljoint press. They did not have the one with the angled adaptors for Jeeps. I used a piece of old fence post that I cut up into various angled pieces with a sawzall and used the one that worked best.
Without the angled adapters the job is a pain, the adapters make it much easier.
The time now is 10:32 AM.
