Front axle? grinding noise - JeepForum.com
post #1 of 1 Old 08-05-2009, 01:13 PM Thread Starter
kc8ztw
When I accelerate in a stright light or while turning left I get this nasty grinding noise from the front end. You have to be accelerating at a good rate... enough to pick the front end up a little at least. Im thinking its coming from the axle but not for sure. I have checked all the suspention components and it doesn't seem to be there, pulled the cover off the front diff and stuff is a little wore but nothing alarming found in the bottom or anything. I thought it was a bad right CV joint so I replaced it free under warrenty and and no luck. I can also feel it a little through my feet if that helps.
I have a Dana 30 front axle and 5.2 V8
Someone else mentioned to me to check to see if the TC bolts are tight and I havent yet becaue this is a long grinding noise that happens the entire time your getting into the throttle in 1st not a clunk but could this still be it?
thanks
kc8ztw is offline
grinding noise from up front leofanti ZJ Grand Cherokee Forum 6 08-03-2009 06:03 PM
grinding noise from front end ryan-5.2zj ZJ Grand Cherokee Forum 3 02-24-2008 02:26 PM
Help w/ front end grinding noise harlow00 ZJ Grand Cherokee Forum 0 02-05-2008 07:50 AM
Grinding Noise From Front End parnell5150 ZJ Grand Cherokee Forum 16 04-10-2007 10:14 AM
Help! What is this grinding noise from front end.. 7tiger7 ZJ Grand Cherokee Forum 4 02-17-2007 06:19 PM
