front axle flex question - Page 2 - JeepForum.com
post #16 of 35 Old 03-31-2014, 08:37 PM Thread Starter
ZJfamilyfun
All due respect, then why are other rigs running w/o. Your argument is contradicting yourself. So you mean to tell me you're running with your end links attached?
ZJfamilyfun is offline
post #17 of 35 Old 03-31-2014, 11:58 PM
D-rey
Originally Posted by ZJfamilyfun View Post
Dey r was that stock? The pics.
I believe that they were stock. Like I said, the PO may have put longer ones on there, but they looked original to me. It worked, but I don't recommend it. I put on extended SS lines as soon as I could.
D-rey is offline
post #18 of 35 Old 04-01-2014, 11:57 AM
JohnnyZJ
you'll break a stock link before it reaches full flex. and quite possibly pop the top of the sway bar link through your fender if you actually do get it up there.
YJ brake lines work well too for extended brake lines
sway bar discos are often sold in tandem to a decent type of suspension that will offer more flex but by them selves are pretty useless in my opinion. especially on a stock ZJ. there is a much cheaper option. just unbolt the stock links when you get to the trail. spend the money on something like an actual lift, or bigger tires.
people buy sway bar disconnects because they don't know any better........ probably read how everyone gets/buys them with a lift kit. i ran a set of discos on my old, old ZJ. last set i'd buy. ran Rough country links on teh last one and just unbolted them at the trail head. was much faster and the joints didn't wear out and clunk.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #19 of 35 Old 04-01-2014, 12:20 PM
PolkaPower
I bent my axle sway link mount off road from not disconnecting them. No flex in a flexy situation, all that force has to go someplace.
PolkaPower is online now
post #20 of 35 Old 04-01-2014, 12:27 PM
CatSplat
1994 ZJ
Originally Posted by Technohead View Post
Note that disconnecting the sway bar does not create additional suspension travel. Connected or not your maximum extension is limited by your shocks.
You're going to have to elaborate on that one. Are you saying that in a purely stock suspension setup, the shocks will max out before the sway links shear off?
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #21 of 35 Old 04-01-2014, 02:19 PM Thread Starter
ZJfamilyfun
I'm fully aware of the physics of suspension systems. Being I'm certified in steering and suspension systems. I'm just trying to get technohead to back his contradicting statements. My only concern was the brake line.
post #22 of 35 Old 04-01-2014, 02:34 PM
Timo_90xj
Timo_90xj's Avatar
Don't mix up axle droop (vertical travel) with suspension flex. Swaybar limits suspension flex (axle articulation) and reduces body roll, but it does not limit vertical movement of the axle. Two different things
If you lift the front or rear of the Jeep up from the body, and let the axle droop, you shouldn't see a difference in vertical suspension travel with the endlinks connected or disconnected. In real life, there can be a slight difference if the swaybar endlink bushings bind, but if there is no binding on the bushings and/or endlinks are long enough there won't be any difference. There will be a LOT of difference in axle articulation though
The newer style front endlinks will certainly bind at some point, but they shouldn't bind before the shocks run out of travel on a stock system. I do know for a fact that even with stock endlinks on 1.75" BB and longer shocks, rear axle will droop just as far down links connected or disco'd if the shocks are mounted.
***Under construction***
Timo_90xj is offline
post #23 of 35 Old 04-01-2014, 02:52 PM
CatSplat
1994 ZJ
Hm, I don't know about the newer-style, but I seem to remember my front old-style sway links binding before the shock maxed out at full droop. To be fair, I have the UpCountry shocks that were a little bit longer - and it was a while ago, I could be misremembering.
At any rate, it's important to make the distinction between straight travel and articulation. Technohead did seem to be saying that the sway bar does not limit articulation (flex) which I have a hard time believing:
It will still flex to the maximum extension with the sway bar connected. Just not as easily and, most importantly, there will be less normal force (i.e. traction) at the tire that is extending.
The Jeep of Theseus
CatSplat is offline
post #24 of 35 Old 04-01-2014, 03:06 PM Thread Starter
ZJfamilyfun
I wasn't looking at purchasing. Just possibly fabbing a sleeve. But just removing is the way I'm going to go. I just got to fab some sort of hanger/ support to keep the sway bar tucked up and out of the way.
post #25 of 35 Old 04-01-2014, 03:11 PM
Timo_90xj
Timo_90xj's Avatar
In theory, you could flex the suspension to the same amount with the stock swaybar connected and disco'd, but the force required to do that is so enormous something would definitely bend/ break.
I was talking about straight travel, not articulation. In real- life situation, there is definitely a big difference in amount of flex with the swaybar connected or disco'd. Ie. with a stock 28mm swaybar, one definitely won't be able to max out front axle travel at an RTI ramp.
Now, keep in mind that systems like Currie antirock are anti-sway systems, which do prevent body roll efficiently, while keeping axle travel very close to maximum. But, that is pretty much offtopic..
As for the stock brakelines, I would not run them at anything higher/ better flexing than a budget boost lift. Braided SS hoses are not that expensive, I'd rather invest in a set of them instead of wondering on the trail where the hell all the brake fluid has gone..
post #26 of 35 Old 04-01-2014, 03:13 PM
PolkaPower
No you don't just push it up out of the way. It will stay. I went though the trouble of fabbing some sway bar holders but I hardly ever used them. This is on rocky trails mostly out in Las Vegas.
If it loosely flops around then your bushings are shot but you already know that since you are all certified.
This is pretty much the same way I made mine. On the drivers side you can use a hole that's for the air box and the pas side I had to drill one. I used them maybe 4-5 times until I realized that the bar never moved even after a rough 30 mile trail.
post #27 of 35 Old 04-01-2014, 03:56 PM
CatSplat
1994 ZJ
I agree. I suspect that even if the sway link didn't break under the kind of load required, you'd have to twist the sway bar in half to even approach max flex. The mass of a ZJ would not even come close to being able to provide that kind of force.
The Jeep of Theseus
CatSplat is offline
post #28 of 35 Old 04-01-2014, 04:42 PM Thread Starter
ZJfamilyfun
Bushings are good. Just never disconnected and driven. Just trying to avoid and eliminate accidental whoops from happening. "Prepare for the unlikely" ...
post #29 of 35 Old 04-01-2014, 04:46 PM Thread Starter
ZJfamilyfun
Rather have them tied up and out of the way to make sure nothing happens then to leave it because the bushings are good and it won't move, then it does for some reason fall down and gets wrapped around a brake line. You know what I mean? If it can be avoided then avoid it.
post #30 of 35 Old 04-01-2014, 05:18 PM
PolkaPower
You have quite an imagination. Have you seen how far apart the sway bar is from the brake lines? I see what you are saying so just do what your comfortable with.
