Front axle bearing replace - JeepForum.com
post #1 of 2 Old 03-19-2007, 07:33 PM Thread Starter
wahoo50
Discovered the right front axle bearing on my 4x4 1997 Cherokee needs replacing. Since I am new to this site, can someone direct me to some good instructions?
wahoo50 is offline
post #2 of 2 Old 03-19-2007, 07:41 PM
Yardman Harry
O
Yardman Harry's Avatar
Here you go man,
http://www.jeepforum.com/forum/f310/how-replace-axle-shaft-wheel-hub-bearing-assembly-w-pics-377208/
The FAQ is good place to start, if you cant find it there, ask here.
The above is on the second page, last post.
Good LUCK!
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
How to replace an axle shaft and/or a wheel hub bearing assembly w/PICS! ArloGuthroJeep WJ Grand Cherokee Forum 339 03-26-2016 07:53 AM
Dana 30 front axle bearing and seal question MrJayDeeM ZJ Grand Cherokee Forum 46 07-12-2014 08:38 AM
How to replace front Axle UCA bushings? ZJcrawler45 ZJ Grand Cherokee Forum 7 10-24-2010 03:21 PM
2000 WJ limited: spun a pinion bearing! Rebuild axle or replace it? kkady ZJ Grand Cherokee Forum 2 01-09-2010 10:37 PM
How to replace wheel bearing Mustang ZJ Grand Cherokee Forum 3 03-20-2009 10:56 PM
