Fresh build backfiring - Page 2 - JeepForum.com
post #16 of 28 Old 04-30-2013, 05:14 PM
HOSTED67
Definitely check fuel pressure. Sounds like it may be good enough for idle but running lean under load.
HOSTED67 is offline
post #17 of 28 Old 04-30-2013, 08:36 PM Thread Starter
bigb229
Fuel pressure checked out at 50psi on the rail.....she's at the shop all alone as we speak. First time my bay ever had strange hands on her.
bigb229 is offline
post #18 of 28 Old 04-30-2013, 09:00 PM
MustangFX93
Did you make sure the spark plugs are gapped correctly?
MustangFX93 is offline
post #19 of 28 Old 04-30-2013, 09:10 PM Thread Starter
bigb229
Yeah. plugs def. gapped correctly
bigb229 is offline
post #20 of 28 Old 05-01-2013, 06:34 AM
speedbucket
New injectors? Old ? New screens and pintles?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #21 of 28 Old 05-07-2013, 05:03 AM
HOSTED67
Fuel pressure 50 psi. Is that while driving or at idle. Needs to be checked while driving and while failing to be an accurate test. Sometimes a fuel pump will not be able to keep up with the needed volume of fuel at speed.
HOSTED67 is offline
post #22 of 28 Old 05-07-2013, 10:13 AM Thread Starter
bigb229
fuel pressure checked out ok. think i have some valve float. gonna pull the head and have it machined for performance springs and drop a comp cam over in it
bigb229 is offline
post #23 of 28 Old 05-07-2013, 10:17 AM Thread Starter
bigb229
I will admit that I never ran the thing to check for the fuel pressure as it will only idle and backfire.....but I've also read in the fsm that it needs to maintain 31 psi while over idle
bigb229 is offline
post #24 of 28 Old 05-07-2013, 10:24 AM
dylantheheeler
Did you check crank position sensor? May be bad, just throwin out suggestions.
Sent from AutoGuide.com Free App
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
post #25 of 28 Old 05-07-2013, 10:26 AM
Jeeples
Jeeples's Avatar
How high in the RPM band was the backfiring occurring? Typically valve float is seen at high RPMs near or beyond redline.
Did you not replace the springs when the head was off last?
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #26 of 28 Old 05-07-2013, 11:18 AM Thread Starter
bigb229
I didn't replace the springs...just cleaned and lapped the valves a little....it idles very smooth...as soon as you put the gas to it it begins to backfire through intake and exhaust. Took it to the shop and they couldn't figure it out either....all of the sensors are new and check out fine. valve train was a bit stiff after the build....sounds like the valves are floating on me.....shoulda replaced the springs. oh well.
bigb229 is offline
post #27 of 28 Old 05-07-2013, 11:46 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Fuel pressure should be 49# at all times. 31# was for the 92-95. Be sure you have the right manual for your year.
Test the map sensor and throttle position sensor.
ratmonkey is offline
post #28 of 28 Old 05-07-2013, 01:40 PM Thread Starter
bigb229
So even through cranking it should not waiver below 49#. All sensors are new and checked out
bigb229 is offline
