Fresh build backfiring - JeepForum.com
post #1 of 28 Old 04-28-2013, 08:17 PM Thread Starter
bigb229
Alright fellas. We just fresh built the 4.0l back to standard. Everything is new. Initially thought it was the timing but its correct. She idles smoothly but when you get on the skinny peddle it backfires through the exhaust and intake occasionally. Thinking fuel pump but haven't checked the pressure on the rail yet. Opinions?
bigb229 is offline
post #2 of 28 Old 04-28-2013, 08:20 PM
jnowak
Did you lap the valves? If not the have to seat in.
jnowak is offline
post #3 of 28 Old 04-28-2013, 08:27 PM Thread Starter
bigb229
Took them out one at a time replaced the seals and lapped them
bigb229 is offline
post #4 of 28 Old 04-29-2013, 07:58 AM Thread Starter
bigb229
bump
bigb229 is offline
post #5 of 28 Old 04-29-2013, 08:16 AM
speedbucket
Any codes?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #6 of 28 Old 04-29-2013, 09:43 AM Thread Starter
bigb229
not throwing any codes...was hoping that it would throw an o2 code and it be an easy fix....NOT!
bigb229 is offline
post #7 of 28 Old 04-29-2013, 11:00 AM
jnowak
New rocker arms? Curious if you got the right ratio.(shipping error) usually if it back fires through intake ,valve is still open on combustion.
jnowak is offline
post #8 of 28 Old 04-29-2013, 06:21 PM Thread Starter
bigb229
Original rocker arms and valves... Just had the seats and seals done checked the fuel pressure today and everything is fine
bigb229 is offline
post #9 of 28 Old 04-29-2013, 06:29 PM
jnowak
How old is the gas? I know my small engines start the crap when I got bad gas.
jnowak is offline
post #10 of 28 Old 04-29-2013, 06:31 PM Thread Starter
bigb229
Also fresh....I really don't want to admit defeat and take this to the shop
bigb229 is offline
post #11 of 28 Old 04-29-2013, 06:38 PM
jnowak
Know your pain. Is there a flame coming out with the tail pipe back fire. Might be a vacuum leak? Try.a good can of carb cleaner on all gasket seams.
jnowak is offline
post #12 of 28 Old 04-29-2013, 07:00 PM Thread Starter
bigb229
No flames. She idles soooo smooth and is solo quiet....no vacuum leaks...I think it's possessed
bigb229 is offline
post #13 of 28 Old 04-29-2013, 07:27 PM
denn34
Sounds like cam timing to me. Timing marks aligned right?
denn34 is offline
post #14 of 28 Old 04-29-2013, 08:56 PM Thread Starter
bigb229
Yeah. Even pulled the cover and reset to tdc and recheck distributor timing....it's perplexing
bigb229 is offline
post #15 of 28 Old 04-30-2013, 02:44 AM
denn34
Is the chain tight... Maybe you got a bad one
denn34 is offline
