freeze plugs - JeepForum.com
post #1 of 13 Old 10-15-2007, 02:56 PM Thread Starter
xj 98/yj 94
freeze plugs
who has replaced them on thier 5.2? i have a couple about to go, are they easy or hard, how expensive are the parts? i have never done freeze plugs before
'98 ZJ 5.2 up-country
xj 98/yj 94 is offline
post #2 of 13 Old 10-15-2007, 03:31 PM
Vestjam
I've only done a 4.0. They are not expensive at all. I got a complete kit for less than $10... Most autoparts stores will have them. I used stainless steel, but some think brass is better. I'm not sure I have an opinion one way or the other.
The only issue you are going to have is... having enough room to get to what you need to. The 4.0 was easy. Fortunately, I didn't have to do anything with the one at the rear of the motor.
There are kits to rent (autozone) that will greatly assist you with removal and installation.
You may consider googling 'freeze plug (expansion plug) removal/installation'. There are lots of good articles.
IMO the most important thing to remember if you are doing it yourself is to make sure you have a clean and dry hole before you set the plug. I used Indian Head glue on mine.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #3 of 13 Old 10-15-2007, 03:40 PM
driabyor
driabyor's Avatar
1994 ZJ
Indian Head works great.. the bad part it somehow will end up on you.
wears off by the way
freeze plugs can be a pain, sometimes it involves removal of accessories. Or the engine
hopefully yours are easy
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 13 Old 10-15-2007, 03:40 PM
driabyor
driabyor's Avatar
1994 ZJ
and one will be under a header
fixed that double post
5.2 liter 242 :)
driabyor is offline
post #5 of 13 Old 10-15-2007, 03:43 PM Thread Starter
xj 98/yj 94
most look like i can get at them from under.. one of them looks like i might need to remove a header tho, that will suck
post #6 of 13 Old 10-15-2007, 03:57 PM
driabyor
driabyor's Avatar
1994 ZJ
http://www.permatex.com/images/Displ...otos/20539.jpg
5.2 liter 242 :)
driabyor is offline
post #7 of 13 Old 10-15-2007, 04:23 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
When I worked in an automotive machine shop rebuilding heads, engines, etc., the only thing we would use on freeze plugs was Permatex #1.
http://www.permatex.com/products/aut..._1_Sealant.htm
and Permatex still recommends it for that use.
I like the brass plugs, only because they're softer than the stainless (= better seal). When installing, make sure the hole is very clean (as mentioned above). Coat the perimeter of the bore, and the perimeter of the new plug with the sealant. ALSO, coat the back of the plug with sealant. This will protect the back of the plug from corrosives in the coolant.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #8 of 13 Old 10-15-2007, 04:53 PM Thread Starter
xj 98/yj 94
how do i pull the plugs out? is it a special tool or do i just take plyers and pull it?
post #9 of 13 Old 10-15-2007, 06:48 PM
indept
If you can directly to them, ram a prybar or BF screwdriver through it & pry it out.
indept is offline
post #10 of 13 Old 10-15-2007, 07:09 PM
lma1973
What are freeze plugs and why would one want to change them? Thanks.
2005 Jeep GCL Hemi
Gibson 3" catback exhaust
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #11 of 13 Old 10-15-2007, 07:20 PM
Country Boy
Bovi-sapiens
Country Boy's Avatar
When I do them on our tractor engines, I just use a very sharp center punch and pop through the center. Works great.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline
post #12 of 13 Old 10-15-2007, 07:26 PM
indept
They are to prevent a frozen engine from cracking the block by popping out if it freezes real bad. Ice expands & could crack it, but the plugs are designed to pop out, relieving the pressure. I've never seen it happen though.
indept is offline
post #13 of 13 Old 10-15-2007, 07:34 PM
SJZ
SJZ's Avatar
The correct term for them is actually a "core plug", and is a remnant of the sand casting process by which the block is cast. Since they are usually made of steel (OEM), they corrode and sometimes need to be changed. When boiling out a block during a rebuild, they are removed in order to allow the caustic solution to freely circulate inside the water jacket.
I usually remove them by holding a punch on one side and hitting it with a hammer. The plug will sometimes rotate in the hole & you can use a visegrip to pull them out. If you punch a hole in the plug, you can pry it out. They are usually very easy to remove... if you can get at them.
-Steve
SJZ is offline
Rubber freeze plugs? Rock1127 ZJ Grand Cherokee Forum 48 01-10-2012 12:29 PM
Freeze plugs CaseyC ZJ Grand Cherokee Forum 0 09-05-2009 08:25 PM
freeze plugs 5.2 wightkliff ZJ Grand Cherokee Forum 1 06-15-2009 10:10 PM
What size are freeze plugs for a 97' 5.2? kjopen ZJ Grand Cherokee Forum 4 09-29-2007 09:12 PM
Got the freeze plugs fixed, Now.... JonM81 ZJ Grand Cherokee Forum 6 08-02-2006 01:09 PM
