Freaking Pitman Arm! - JeepForum.com
post #1 of 9 Old 11-26-2008, 06:03 PM Thread Starter
JrMechanic
So, I got my new steering box today... Upon getting under truck I realized I needed a BF socket. Closest I had was 1 1/8, so I went and got a 33mm, no big deal. Got that off, and soaked the pitman arm in PB blaster, let it sit and pounded on the gear box shaft to remove the pitman arm... No way, so I started hammering on every angle possible with the BFH, didn't budge... Heated it up till it was red hot... Nothing. F!@#. Im off to get the puller from AZ.
Anyone know if I have to remove the steering stabilizer to allow the drag link to drop enough? I don't want to remove the drag link from the pitman arm...
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #2 of 9 Old 11-27-2008, 12:20 AM
Upside
No I didn't remove the steering stabilizer. The puller was definitely necessary to get the arm off of my steering box.
Upside is offline
post #3 of 9 Old 11-30-2008, 04:56 PM
srad711
2003 WJ
I just did one a month agao on a friends jeep. I had to cut it off after breaking two pullers and heating it to no end. I have taken off about 10-15 of them and 3 needed to be cut off.
srad711 is offline
post #4 of 9 Old 11-30-2008, 06:27 PM
psychoworks
A friend of mine just did a drop pitman arm on his YJ. Had to burn it off with the fire wrench.
I shop in the salvage yard!
psychoworks is offline
post #5 of 9 Old 11-30-2008, 06:37 PM
newfieZJ
Puller , air impact gun , and a hammer to tap it as you apply more pressue , always worked for me
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #6 of 9 Old 11-30-2008, 07:02 PM
shadetree
When I originally did my lift I was trying to remove the drag link from the pitman arm (for ease of installation)=I was new to lifting a grand. Anyway I destroyed a pitman arm puller and luckly I didn't have to pay for it because the shop foreman was there and agreed that I did nothing wrong.
Peace of mind....sometimes they need to be torched off!
"If I can't buy it or borrow it, I don't need it"
-1994 ZJ Lifted and Locked...
-1983 CJ7 4.2ltr/Dana 300/Warn F&R bumpers...and some other goodies.
D.W.A. (Death Wobble Anonymous)
shadetree is offline
post #7 of 9 Old 11-30-2008, 08:01 PM
sensera7791
I just did my box last week. I took the draglink off and dropped the old box out with the pitman arm still on. Put it on the workbench vice so I could work on it easier. Well, bought the AZ puller, put my breaker bar on it, did as much pulling as I could. Went for the 3 foot piece of pipe I keep around for leverage. freakin breaker bar shatters! flew all over the place. Pitman arm 1 me 0. So i figured I could just tap the end of the puller and it should pop off. nope. tap harder and harder with 5lb sledge. head breaks off. pitman arm 2 me 0. So now I get really P-edd off. I get a bigger hammer and start beating the the side of the puller arm, downward, all the sudden the puller shoots across my 2 car garage, pitman arm flys over and hits my headlight and breaks it. WTF. pitman arm 3 me 0. but I did get the dam thing off. And this WAS after soaking in PB blaster.
sensera7791 is offline
post #8 of 9 Old 12-01-2008, 04:15 AM
Colorado 5.9
Colorado 5.9's Avatar
1: Install puller on pitman arm. ( Steering box side)
2: Tighten pitman arm puller until very tight.
3: With small sledge hammer. Pound pitman arm puller bolt on the end a few times.
4: Retighten bolt.
5:Pound bolt again a few times.
6: Repete steps 5 & 6 untill pitman arm comes off.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #9 of 9 Old 12-01-2008, 04:16 AM
Colorado 5.9
deleted......
AIR BAG light freaking me out!!! nelson1248 ZJ Grand Cherokee Forum 4 05-26-2009 01:00 AM
Heater freaking out on me dcvance87 ZJ Grand Cherokee Forum 1 03-19-2009 09:37 PM
Freaking Lug Nuts! JrMechanic ZJ Grand Cherokee Forum 45 03-09-2009 10:19 PM
GSW DW Freaking out etc... ArloGuthroJeep ZJ Grand Cherokee Forum 28 06-06-2006 11:56 PM
Headlights Freaking Out BlackBlt3D ZJ Grand Cherokee Forum 7 11-19-2005 03:07 PM
