Frame rust repair and IRO Frame Stiffener install! (Pics) - JeepForum.com
post #1 of 13 Old 06-21-2016, 10:23 AM Thread Starter
Henyaman
So I finally caved and realized I HAD to get the rust fixed in my rail where the AC ruined it for years. With the long arms in the front it was just going to be a matter of time with the extra stress. So I found a good local welder and off we go!
First up, a pic of the damage. It started to stress crack on the side recently so it was time/dangerous:
Crossmember off. Not looking too hot...
This is all that was really holding me in on that side. The other side was solid, just the AC/Passenger side was bad. I was surprised how much was eating top down too, it was thinner than I anticipated.
After he plated and added angle steel in. Inside was done as well but it was an odd angle to get a picture of:
IRO stiffener, which also covers the once weak spot and has pre-drilled holes for their crossmember:
Plug welded, ground, and primed:
Done and painted right side (Where there was just a hole)
And the driver side, which just got the stiffener and paint:
Given how relatively cheap the stiffener is and how common that area is to rust, I would recommend the stiffeners without hesitation. I don't have to worry about randomly dying now when it gives way, and you can tell when going over speed bumps its the suspension soaking it up, and the chassis back and forth is much less than it used to be. Maybe that part was weaker than I realized, but going over bumps at an angle would toss me back and forth, now its just one wheel at a time. Very happy!
1996 ZJ 5.2L, 33x12.5 BFG AT
IRO: 5.5" Kit, OTK, Exhaust, BPE, Stiffeners
KOR: PS Brace
Henyaman is offline
post #2 of 13 Old 06-22-2016, 04:34 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
That was a lot of welding but it looked good as far as my knowledge goes. What do the bolts screw into?
Originally Posted by HighLonesome
coralman is offline
post #3 of 13 Old 06-22-2016, 05:13 PM
Ted_Z
Aren't you supposed to weld up the vertical seams?
Ted_Z is offline
post #4 of 13 Old 06-22-2016, 06:19 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes.
kg6mov is offline
post #5 of 13 Old 06-22-2016, 08:15 PM
LowBudgetZJ
The iro cross member uses a combo of the existing tapped holes and new holes that the installer must drill in the rails.
98 ZJ 4.0 42RE NP242
75 CJ5 232 T14 D20.....STOLEN
LowBudgetZJ is offline
post #6 of 13 Old 06-22-2016, 10:15 PM
Candymancan
Looks better then my welds, well i assume you cleaned em up with a grinder first.. my welds of course my first ones looked like blobs of poops. However, I suggest you do not stack plates over metal.. This is one big thing that actually causes rust.. I have several area's on my wagoneer where the c channle rusted out due to support brackets and other peices of metal bolted on top or overlaping and over the years it completetly rotted the frame behing it, and thanks to none of the previous owners removing the brackets.. I have to cut out and re-weld the c channle.
ZJ's also rust in areas where metal is stacked on metal.. The frame is rusting because the frame is joined together by two peices inside there, the frame also likes to rust where the trans cross member is bolted to it, and also likes to rust where the trailer hitch and gas skid is bolted to it.
Its not the A/C really causing it, its rusting from the torque box inside out, my moms 4.0 had the same issue
Candymancan is offline
post #7 of 13 Old 06-23-2016, 09:23 AM Thread Starter
Henyaman
We primed everything before welding so its as good as its going to get for now. Give that the total thickness there is well over 1/2" and probably closer to 3/4", its probably going to outlast the rest. I may get one of those long attachment paint cans and spray inside the rails where it was repaired too. Good news is I am in NC now so the salt and snow doesn't do the damage it does elsewhere.
Every time I go to the junkyard here it makes me mad how nice and clean these southern frames are. Of course, mine was from up north so I wasn't so lucky.
Oddly the other side of the frame was fine, nothing structural at all. This side was 100x worse. Thats why I got the stiffeners mainly to beef up the area that is known to rust, so with that extra 3/8 or so I bought as much time as I can!
KOR: PS Brace
Henyaman is offline
post #8 of 13 Old 06-23-2016, 09:29 AM Thread Starter
Henyaman
AH, it didn't come with any paperwork so the welder just did what I told him to.
I thought the breaks were just to form fitment, but if they need welded as well I will have it done when we do the sliders and floor pan next.
All my other IRO came with paperwork but this one. It just said plug weld on the site so that's all we did. The picture on their site is just a hold up, not welded in pic so I wasn't sure.
KOR: PS Brace
Henyaman is offline
post #9 of 13 Old 06-23-2016, 09:39 AM
kg6mov
Hears the voices
kg6mov's Avatar
This is an XJ, but yes you're supposed to weld pretty much everything.
kg6mov is offline
post #10 of 13 Old 06-24-2016, 01:15 AM
Candymancan
Itll still rust over time but that is pretty thick... Just remember with an airbag system and a frame that stiff your airbags might not go off.
Also if your frame was that rusty i suggest take a good look inside the torque box. Its that box your picture here on the very far right thats partially painted.. the frame rusts inside there.
Here is what it looks like it looks perfectly fine until you peal the undercoat away and then the metal just falls off and i found the frame rusting in here. Even my 5.9 zj with 0 rust has surface rust in this stupid box
post #11 of 13 Old 06-24-2016, 04:24 AM
PolkaPower
I am under the impression that the airbags deploy with a measure of deceleration not impact.
PolkaPower is online now
post #12 of 13 Old 06-24-2016, 06:43 AM
Pierre_r
1989 XJ Cherokee
Its a 15years+ vehicle so even with the bad frame i would not count on it being deployed at all in a crash.
I know Volvo only expected them to last for about 9years in their 940model.its about the same age as the zj,s are now.
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline
post #13 of 13 Old 06-24-2016, 09:35 AM
Uniblurb
Uniblurb's Avatar
Just curious Candy why you think the AC drain water dumping into the passenger side frame wouldn't cause it to rust much more than the driver's side of the frame w/o drain water?
My 96 is the same way with the passenger side frame rusting out much more than the driver's side. I blame it on the AC drain water sitting in there rusting it from the inside out. And reason I routed the drain water into the wheel well area outside the frame in the below write-up I did.
http://www.jeepforum.com/forum/f13/a.../#post31953314
If you look at post #11 you can see where the frame box is rusted a lot more on the passenger side than the driver's side in the 2 photos.
http://www.jeepforum.com/forum/f13/a.../#post31966554
Poor design to begin with in routing the AC water into the frame. And it doesn't help the drain hole in the bottom/front has a lip on the inside about 3/16"-1/4" tall which helps trap the water instead of letting it drain out. You can see this in the 2nd above photo.
PS. guess I never though about my airbags not deploying because they're too old.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
