Found My 8.8!!!! - JeepForum.com
post #1 of 42 Old 09-27-2006, 03:03 PM Thread Starter
randyszj94
randyszj94's Avatar
1994 ZJ
Found My 8.8!!!!
ok i think i found a 8.8 its kinda different for the reason... so somone double check this and tell me if im right...
its old as crap tho has dang 3.27 gears annd the down fall is this
drums
so is this the ford 8.8 that iv been lookin for? i payed 70$!!!!!! for this...
PUMA were r u at.. give me a hand fixing this..
randyszj94 is offline
post #2 of 42 Old 09-27-2006, 03:08 PM
D-train
looks like its out of a ranger.
so it has 28 splines and not 31.
D-train is offline
post #3 of 42 Old 09-27-2006, 03:10 PM Thread Starter
randyszj94
randyszj94's Avatar
1994 ZJ
is that bad ? can if b fixed?
it was sittin on top an explorer
post #4 of 42 Old 09-27-2006, 03:12 PM
D-train
well it could have been out of an explorer, just one of the older ones.
since it has drum brakes, it is a 28 spline.
not sure if you could swap in 31 spline shafts.
D-train is offline
post #5 of 42 Old 09-27-2006, 03:14 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
You'd have to get a different carrier and I'm not sure it would fit.
Darn the bad luck.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #6 of 42 Old 09-27-2006, 03:16 PM Thread Starter
randyszj94
randyszj94's Avatar
1994 ZJ
dangit! woody plz dont tell me that!!!
alrite so tell me the good news... what can i change on it? will it work on my jeep. and its still better then the dang D35 correct?
post #7 of 42 Old 09-27-2006, 03:18 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Thats not correct.
All Explorer axles are 31 spline, even the drum brake equipped ones.
To determine if this is an Explorer or Ranger axle, take a quick WMS to WMS measurement. If its around 59", its an Explorer axle. If its closer to 56-57", its a Ranger axle.
Wheelin98TJ is offline
post #8 of 42 Old 09-27-2006, 03:18 PM
Woody
Woody's Avatar
1985
It's a little bit better. I would search for a 31 spline though.
Woody
Woody is offline
post #9 of 42 Old 09-27-2006, 03:19 PM Thread Starter
randyszj94
randyszj94's Avatar
1994 ZJ
Originally Posted by Wheelin98TJ
Thats not correct.
plz define that..... whats WMS ?
post #10 of 42 Old 09-27-2006, 03:20 PM
Woody
Woody's Avatar
1985
That's also very narrow for your application. You were already going to need spacers, but that's a bit much. IMO.
Woody
Woody is offline
post #11 of 42 Old 09-27-2006, 03:20 PM Thread Starter
randyszj94
randyszj94's Avatar
1994 ZJ
from the inside of drum to inside of drum its like 53?
post #12 of 42 Old 09-27-2006, 03:20 PM
Wheelin98TJ
JEEP FREAK
WMS = wheel mounting surface
post #13 of 42 Old 09-27-2006, 03:24 PM
Wheelin98TJ
JEEP FREAK
Okay, just looked at the pics again.
Thats definitely an Explorer axle.
Its spring under which Explorers are.
Rangers are spring over.
post #14 of 42 Old 09-27-2006, 03:38 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
Get a ARB locker made for 3.73's and up so you can run gears to match your front and do a disc conversion and you are set. Thats cheap right?
2013 FR-S
BlaineWasHere is offline
post #15 of 42 Old 09-27-2006, 03:52 PM
D-train
Thats not correct.
my bad, i just realized that.
sorry for the incorrect information.
D-train is offline
I found a 242 shdybrady19 ZJ Grand Cherokee Forum 28 05-31-2009 10:13 PM
I Think i Found the Right One Mr Q X ZJ Grand Cherokee Forum 3 10-31-2006 05:12 PM
Found It!!!!! ynotyj ZJ Grand Cherokee Forum 8 03-10-2006 11:32 AM
Look what I found 10achik ZJ Grand Cherokee Forum 21 03-07-2006 01:46 PM
I found mud jeepholic ZJ Grand Cherokee Forum 4 12-17-2004 07:32 PM
