Quantcast Found a Ford nine now what for the front? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Found a Ford nine now what for the front?
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 03-23-2007, 06:56 PM   #16
micifus
Original GC'er
micifus's Avatar
Dang! where did you get those tie rod ends? That is what I should of bought
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 03-23-2007, 07:09 PM   #17
zaq123
1941 MK Compass
Those are just regular heim joints. They are illegal (offroad only) to have in the steering as per USDOT. If you have state inspection in your state, they will fail you for them. However, they are fine for the suspension, go figure
Unfortunately, those aren't mine, I wish I had WJ knuckle conversion.
zaq123 is offline   Reply With Quote
Old 03-23-2007, 07:43 PM   #18
gunthagunth
Originally Posted by zaq123
Good luck installing rear XJ "coils" on ZJ TJ rear coils are wider that ZJs + rear track bar bracket is totally different + TJ's control arms brackets are angled where ZJ ones aren't.
PS. I believe Claytons have ZJ kit, not 100% sure though. Some ppl just chop of D35's brackets
Clayton does have a bracket kit. The control arm brackets will fit fine. The shocks will fit, not sure about the rear swaybar brackets. The trackbar bracket I am unsure of but I will not need it with claytons kit going on. If the coil buckets are too big then they should fit the zj coil fine I would think.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Claytons/JKS Control arms out back/Addco's/RE brake lines/35"TSL SSR's on 5.9rims/Currie steering/K&N/JKS rear trackbar/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/D30lockrite D44a
gunthagunth is offline   Reply With Quote
Old 03-23-2007, 09:36 PM   #19
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
I would say D44HP. Same width, driver side drop. Plus you would able to get discs brakes on them. Not sure if Waggy axles had disc brakes.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 03-25-2007, 08:36 PM   #20
gunthagunth
Okay, I bought the axle but I was surprised when I saw that it was the short wheel base bronco width. WMS is 57 5/8. Thats like 2" shorter than the zj axles if I am not mistaken. Now up front I am still wondering what to do. I was wondering if there would be a way of running a Hp30 up front, figuring out how to do a cheap hub 5x5.5 conversion, and adding 1" wheel spacers on the rear. I have no issues where I live with the dana turdy other than the crummy brakes. Figured it would be easier to swap a HP30 and cheaper because I would not need a bracket kit. Maybe a super 30 with a truss would be ideal for 35's. I dont know if the early broncos were equipped with a 44 front end or a 30. Looks like I have some research to do.
Old 03-25-2007, 09:08 PM   #21
jfowlzj95
Yeah the EB WMS is small and they did have 44s they were just low pinion. You could run adaptors in the rear to get your 5x4.5 BP, or do they make those? You could get some custom shafts from Currie or so, but then again more $$$.
95 zj with some big n heavy crap!
jfowlzj95 is offline   Reply With Quote
Old 03-25-2007, 09:52 PM   #22
gunthagunth
http://cgi.ebay.com/ebaymotors/Wheel-Adapters-5-Lug-Choose-Different-Sizes-1-Thick_W0QQcmdZViewItemQQcategoryZ42614QQitemZ29008 7888389
Perfect, 1" wheel spacers/adaptors. Cost much less than the warn hub conversion but I get the less desirable 5on4.5 pattern.
Old 03-25-2007, 11:06 PM   #23
BlaineWasHere
Addicted to Boost.
BlaineWasHere's Avatar
If you want to run the HP30 just leave it 5on4.5 then when you get the spacers to make the rear alittle wider to match get ones that change the lug pattern from 5on5.5 to 5on4.5... That is way cheaper than a D30 hub conversion sence you would need to buy the spacers anyway.
EDIT: I did not read and I guess this was already suggested. Great minds think alike!
2007 VW GTI
BlaineWasHere is offline   Reply With Quote
Glock Forum
