Found a Ford nine now what for the front?
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
I located a 9" rear end out of a bronco. It has thunderbird calipers, 4.56 gears installed, new bearings, 28 spline and the housing has been cleaned, hot tanked, and painted. 400 bucks!
![]() ![]() I just bought the RE TJ bracket kit off JU and i'm hoping the coil buckets will work with the zj coils. Now I need to figure out the front. Should I go with the Hp44 to match or should I go another route. Just looking for what people suggest. Not sure if a waggy 44 would be better for me or not. I have to figure room for brackets and the option of highsteer would be nice. Kinda want a housing that would not need to be retubed. Anyone know what year dana 44 the TNT customs truss kit was made to fit?
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Claytons/JKS Control arms out back/Addco's/RE brake lines/35"TSL SSR's on 5.9rims/Currie steering/K&N/JKS rear trackbar/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/D30lockrite D44a |
#2 |
Addicted to Boost.
Are you going to run 35 spline shafts in the 9"?
2007 VW GTI |
#3 |
I plan on doing a 35 spline upgrade once the axles are in. Right now the carrier is open. I plan to add a locker and 35 spline upgrade once everything is installed and rolling under claytons. Figure I can get some cash just selling the third member and shafts once I build up a 35 spline member.
#4 |
Jeep Jedi Master
44 from a Scout.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#5 |
Nice find.
I don't think TJ spring brackets will fit zj. How big are you going with tires? I think Super D30 with WJ knuckles would do it for under 35"s something like this. WJ rotor/caliper upgrade would be nice but it takes some custom work ![]() |
#6 |
I'm going 35's maybe more. I looked into the scout axles but they are pass drop. Not sure if I could convert a drivers drop waggy to 5x5.5. I think my only option would be a ford 44 to match the width and have high pinion.
#7 |
Addicted to Boost.
Ford F250 HP44 with F150 5on5.5 outers.
2007 VW GTI |
#8 | |
#9 | |
TJ rear coils are wider that ZJs + rear track bar bracket is totally different + TJ's control arms brackets are angled where ZJ ones aren't.PS. I believe Claytons have ZJ kit, not 100% sure though. Some ppl just chop of D35's brackets Last edited by zaq123; 03-23-2007 at 05:19 PM.. |
#10 | ||
http://www.rubiconexpress.com/Products.aspx?Cn=345&Pn=1704&XnPath=320,322,345&Vi d=AB27E41102353 At the bottom it says......... Quote:
You can also read the 2nd paragraph there. They will work. Edit: And I thought you were just talking about the coil buckets....not all of the other brackets. |
#11 | |
Addicted to Boost.
Smarty pants, who said anything about front coils... we have been talking about a rear axel this whole time.
2007 VW GTI |
#12 | |
from my experience owning both, TJ and ZJ.
TJ rear coils are wider than ZJs. BB kit will fit due to rear TJ coils being tapered on the top ![]() ![]() Quote:
we are talking about rear 9" and I don't see how BB is related to the axle bracket kit With all due respect, why would you want to make a statement like that if you aren't sure what you are talking about. Some ppl can just blindly believe you and go waist their money on TJ kit when it doesn't work on ZJ Last edited by zaq123; 03-23-2007 at 07:24 PM.. Reason: damn links |
#13 |
Addicted to Boost.
TJ rear coils do however look like WJ rear coils.
2007 VW GTI |
#14 | |
And for it being a rear axle, if they were all the same diameter, then you could use the XJ fronts in there whether it was a rear or front axle. Also, for the BB relating to the brackets, in your first post you said the "spring brackets" so I thought you were talking about just the coil buckets. |
#15 | |
Addicted to Boost.
2007 VW GTI |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
