Found It!!!!! - JeepForum.com
post #1 of 9 Old 03-10-2006, 08:01 AM Thread Starter
ynotyj
ynotyj's Avatar
Found It!!!!!
So I bought a 96 ZJ (I6) with 111000 miles on it. So far, I love it, but unless I'm accelerating hard, it takes its time shifting from 1st to 2nd. I wanted to check the tranny fluid, but couldn't find the dipstick. My owners manual and my Haynes directed me to the rear of the engine compartment on the passenger side. After an extensive search, it turned up on the drivers side behind and well below the air intake. My question: Is anybody else's there, or should I be concerned about some massive custom work that took place in the past? Incidently, the fluid was a little low. I may change it soon, but will bringing the fluid up to the proper level correct my shifiting problem?
ynotyj is offline
post #2 of 9 Old 03-10-2006, 08:33 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Bringing fluid up to the proper level cannot hurt and will probably help the shifting.
I think you've got a modification, because I've never seen one there and the dipstick for a 42RE is on the left side when looking from the bumper. You might have a different tranny. I'll do a little research.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 9 Old 03-10-2006, 08:42 AM
Woody
Woody's Avatar
1985
Well, after doing some research, both the AW-4 and 42're have the dipstick tube on the left side while looking from the front bumper. Look where it mounts on the tranny. Does it curve around the oil pan or does it go straight into the tranny on the right side?
Woody
Woody is offline
post #4 of 9 Old 03-10-2006, 08:43 AM
Tuff93
Mine is on the driver side rear below the intake also. Sounds normal to me.
Tuff93 is offline
post #5 of 9 Old 03-10-2006, 08:48 AM
Woody
Woody's Avatar
1985
Did they change it in 95? Mine was right under the A/C lines on the pass side.
Woody
Woody is offline
post #6 of 9 Old 03-10-2006, 09:20 AM
spuddybuddy
Mines on the drivers side too, same spot.
'97 ZJ Laredo
- 4.0L
- 176K, runnin like a champ
'06 G35 Coupe 6MT
- A bit faster than the ZJ
spuddybuddy is offline
post #7 of 9 Old 03-10-2006, 10:41 AM
Woody
Woody's Avatar
1985
That makes me feel better. They must've changed the location in 95 or so.
Woody
Woody is offline
post #8 of 9 Old 03-10-2006, 12:27 PM
theone13
Yeah on my old '95 it was on the driver side.
-Steve
'95 ZJ Laredo 4.0L 4x4 : Stolen
theone13 is offline
post #9 of 9 Old 03-10-2006, 12:32 PM Thread Starter
ynotyj
ynotyj's Avatar
Thanks for the input. I was concerned that a prior owner had done something radical. I guess they changed it without updating the manuals.
ynotyj is offline
I found a 242 shdybrady19 ZJ Grand Cherokee Forum 28 05-31-2009 11:13 PM
I Think i Found the Right One Mr Q X ZJ Grand Cherokee Forum 3 10-31-2006 06:12 PM
Found My 8.8!!!! randyszj94 ZJ Grand Cherokee Forum 41 10-02-2006 09:50 AM
Found the best mod for my WJ 10achik ZJ Grand Cherokee Forum 21 03-03-2006 06:34 PM
I found mud jeepholic ZJ Grand Cherokee Forum 4 12-17-2004 08:32 PM
