Ford Taurus Two Speed E-Fan Install (pics) - Page 9 - JeepForum.com
post #121 of 244 Old 04-05-2010, 03:18 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
yes this one
SPDT with Center Off Flat Lever Heavy-Duty Toggle Switch - RadioShack.com
Fan either off or low or high, you will need 2 relays, one for High one for Low. The low relay can be a regular 30-40 amp. I'm thinking you want something like this
Don't forget to turn it on
HighLonesome is offline
post #122 of 244 Old 04-05-2010, 03:23 PM
SplitNail
Yup thats exactly how im gunna do it. Thats what I had in mind the whole time! Thanks for doing that for me! I just wanna find nice looking switch that looks somewhat stock.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #123 of 244 Old 04-05-2010, 03:25 PM
SplitNail
I wont forget to turn it one because low should be on all the time.
post #124 of 244 Old 04-05-2010, 03:37 PM
HighLonesome
You will need to use ignition 12vdc then or the fan will not ever turn off. So the switch will connect to ignition instead of the battery then.
post #125 of 244 Old 04-05-2010, 03:45 PM
SplitNail
Yea I have it pinched in with a fuse to give the relay signal now. But when I get the switch Ill send the signal to the switch then when I flip it to high it will turn low off but when its on low and when the jeep is off it will all turn off. Does that make sense? Instead of getting the trigger from the battery its coming from "Transmission solenoid" fuse.
post #126 of 244 Old 04-15-2010, 11:17 AM
Dirtyjane
I didn't see it mentioned, does anyone have the dimensions on this fan/shroud combo.
06 LJ, 5.5LA, 331350s
Dirtyjane is offline
post #127 of 244 Old 04-15-2010, 01:16 PM
SplitNail
I can measure it later for you.
post #128 of 244 Old 04-15-2010, 01:40 PM
Dirtyjane
I would appreciate that!
post #129 of 244 Old 04-15-2010, 01:41 PM
SplitNail
Prolly 4-5 hours from now.
post #130 of 244 Old 04-15-2010, 01:52 PM
Dirtyjane
No worries sir I appreciate it whenever its convenient for you!
post #131 of 244 Old 04-16-2010, 10:40 AM
Dirtyjane
Bump for some dimensions!
post #132 of 244 Old 04-19-2010, 06:04 PM
jeepguy98
Anyone do the swap with the 5.9 fan and sensors? How would you wire it using the sensors so it comes on and off automatically?
97 JGC Limited 5.2L, Black/Black, NP242 swap, D44a with LSD, 3.73 Gears, 2" IRO lift, Zone Nitro shocks, BFG KO's, Doug Thorley Headers, Magnaflow High Flow Cat, Flowmaster Super 44, Custom Tail Pipe, 5.9 E-Fan Conversion, SCT Tune by Sean, K&N FIPK, Amsoil filter/Pre-filter, MSD 6AL Ignition Box, Blaster SS Coil, Alpine Type-S speakers, Alpine 500W Amp, 10" Kicker CVR, Receiver Shackle, Custom Dash Bezel
jeepguy98 is offline
post #133 of 244 Old 05-24-2010, 03:06 AM
SA59GRAND
See if this helps with the measurments Taurus 2 speed fan
SA59GRAND is offline
post #134 of 244 Old 09-07-2010, 05:58 PM
snotrod
so i got my dc controls 2 spd unit, and i decided against using a 17 year old fan from a taurus, so i started shopping around for different options, and i found an excellant one, if you're willing to spend the dough. its from Derale, part number 16919, its a 2 speed, flows 2400 cfm, and the metal shroud almsot fits the zj radiator perfectly.. just a thought for anyone not wanting a junkyard replacement.
snotrod is offline
post #135 of 244 Old 09-12-2010, 02:28 PM
Billyjoebob007
Originally Posted by EMTimZJ View Post
Here is a picture of where I pulled the wires to the switch through the fire wall. The round black object you see is the brake booster on the drivers side of the engine bay.
Close up: you can see the coat hanger I used to poke through from the inside. Hook your wires to it and fish them back through.
I temporarily removed the washer fluid reservoir while I fished the wires through. It removes by unscrewing the two 3/8 bolts on either side, piece of cake.
Careful, the cap is not water tight!
Wires come through on the other side…
Something i found that works well with the issue of loosing washer fluid is to place a somewhat thick piece of plastic , lay flat over the opening and close the cap. No more leaky
You lose quite a bit of washer fluid after you fill it up say to the top cause when vehicle is in motion the fluid sloshes around and comes out of the top even with the cap on. The plastic works like a charm.
Billyjoebob007 is offline
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 11:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 02:27 PM
finally installed my ford taurus fan MEinSoCal ZJ Grand Cherokee Forum 12 08-11-2008 07:13 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 08:49 PM
Ford Taurus 2 Speed Fan Swamp Boy ZJ Grand Cherokee Forum 11 01-13-2004 03:38 PM
