Ford Taurus Two Speed E-Fan Install (pics) - Page 8 - JeepForum.com
post #106 of 244 Old 01-29-2010, 01:25 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by 4x4fisherman View Post
thanks i did just that. and now its all done . the only thing im concerned about is the temp sencer. do i make a hole in the radiator fins, (oh by the way i have the dc controler unit) thanks again
Do it right the first time. Use one of these, they make them for 1.5" and 1.75" hoses.
Flex-a-lite 32082 - Flex-a-lite In-Line Radiator Hose Adapters - Overview - SummitRacing.com
HighLonesome is offline
post #107 of 244 Old 02-11-2010, 07:46 AM
YelloJeep
This may be a dumb question that has already been covered but..... I keep seeing people talking about buying relays, fuses, temp sensor, etc...for the install. Why can't you just pull the needed items from the donar Taurus? I'm definitely a electrophobe when it comes to electrical stuff but I would like to do this to my 2.5 on the cheap/easy. It seems to me that the stuff needed for it to run right should be on the Taurus (follow the wires)?. Someone set me straight.
YelloJeep is offline
post #108 of 244 Old 02-19-2010, 12:37 AM
Spike300
Yea i need to be set straight to as i very interested in this
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #109 of 244 Old 02-22-2010, 02:42 AM
revlis240
1994 ZJ
more than likely, the taurus uses an ECU controlled system and the wires that power the fan arnt as "simple" as taking 1 wire from the batt, another from the switch, and rigging a relay.
The relay SEEMs complex, but its VERY simple. I didnt read all 8 pages, but just get a thermo-controlled trigger for the fans and forget em! Thats what ill be doing
Cliff notes: tracing the wires/relays/etc that control the factory setup is FAR more complicated than a 4 wire relay...
1994 ZJ 4.0 4x4 almost stock | 1994 ZJ 5.2 4x4 totally stock
revlis240 is offline
post #110 of 244 Old 02-22-2010, 04:58 AM
YelloJeep
After thinking about it, I realized it was probably going to the ECU and yes, just easier to go find a relay elsewhere. Went to the junkyard this weekend and found plenty of fans and plenty of relays. Oh yeah, I read on here somewhere about Cadillacs having the waterproof relays and that is right also. I got several out of a Caddy, all I know is it was a "northstar?". I love the junkyard..... I recommend them to anyone.
post #111 of 244 Old 03-20-2010, 08:57 PM
gharris54
Over the last year my wj has been plagued with cooling problems due to the relay and fan motor so I am really leaning towards doing a taurus fan set up on it but after tons of searching I still cannot find anyone that has put a taurus fan in a 4.0 wj. Does anyone know if the taurus fan will fit in my wj?
2000 dubya jay, IRO 3'' and 265/75R16 bighorns, quicker discos, custon spring retainers, custom ford 9'' rear end with the stock wj discs
Dana35 SOLID diff cover and a lock-right locker for a Dana35 for sale
gharris54 is offline
post #112 of 244 Old 04-03-2010, 11:13 PM
SplitNail
Does anyone know where I can get a good relay for high without spending an arm and a leg. Someone said $10 earlier in the thread but the link isnt working. Please help its getting how outside!!
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #113 of 244 Old 04-04-2010, 08:22 AM
HighLonesome
The 70-amp relay will handle any efan. Get the socket too, makes install easy.
Minute Man Electronics Mobile Relays and Sockets
post #114 of 244 Old 04-04-2010, 08:31 PM
SplitNail
Do you have a wiring diagram that would work for this application? Im confused on something.
post #115 of 244 Old 04-05-2010, 04:57 AM
YelloJeep
I got my relays out of a Cadillac at the junkyard while I was getting my taurus fan. I got three of them in case one didn't work. They were about $2 a piece I think. They were the heavy duty water proof ones. I don't know how much Amperage they are meant for but I think one was for the e-fan on the cadillac and they all had the same part #. My fan is working great. Oh yeah, they only have 4 wires on the plug, but five terminals inside the relay so I did have to rob a wire out of another plug to make a relay with the five wires. I would recommend the junkard relays before spending a bunch of money on new one(s).
post #116 of 244 Old 04-05-2010, 08:02 AM
HighLonesome
There is a diagram in this thread. Here's another
http://www.jeepforum.com/forum/f13/f...begins-355400/
post #117 of 244 Old 04-05-2010, 10:54 AM
YelloJeep
Go to this thread : http://www.jeepforum.com/forum/f8/li...s-50-a-962825/
They are talking about junkyard relays. There is a pic of the type relay I am using from a Caddilac. The one that comes with the bracket. Working fine for me and was cheap.
post #118 of 244 Old 04-05-2010, 11:06 AM
SplitNail
I orded my relay for $10 thanks though! I just need a switch not to be able to turn on high. When I turn on high does low have to turn off?
post #119 of 244 Old 04-05-2010, 11:08 AM
HighLonesome
yes, you will smoke the fan motor if you apply voltage to low and high at the same time.
post #120 of 244 Old 04-05-2010, 11:43 AM
SplitNail
Is there a switch that will control both? Like when i go to high it will turn low off? I dont want 2 switches.
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 10:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 01:27 PM
finally installed my ford taurus fan MEinSoCal ZJ Grand Cherokee Forum 12 08-11-2008 06:13 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 07:49 PM
Ford Taurus 2 Speed Fan Swamp Boy ZJ Grand Cherokee Forum 11 01-13-2004 02:38 PM
