#91 | |
Ok, well my fan isn't connected to the serp belt at all. It does however, have a cable running to what looks like the relay box? This is an Australian Vehicle imported though, I think they may have different specs over there? Or they just had it changed when they got here? I will try and post a pic so I can show you properly what I mean.
#92 |
sorry to bring back an old thread and sorry if what im looking for was already covered and i missed it but i got my fan and the relays, now i just have to pic up some wire so i can do this mod over the week.
i already have how im doing the wiring all drawn out, i jus have a few questions and some things to verify. 1. is the fan supposed to be blowing away or towards the motor? 2. what wire is for what on the fan itself? obviously black is ground but what one is low and high? want to verify this: -wire from battery to relay and relay to fan for low i will run 10 gauge -wire from battery to relay and relay to fan for high i will run 8 gauge -30 amp relay run an inline 30 amp fuse -75 amp relay run an inline 60 amp fuse -wire from switch to relay i will run prob 12-14 gauge or bigger? thanks guys ![]()
98 ZJ Limited 5.2, Blacked Out, 5.5" lift made with IRO coils and ACOS, 15x8 Pro Comp 97's, 33x12.5 General Grabbers, Custom Front Bumper, Rusty's Disco's, KOR Light Bar, 8000K HID's, Magnaflow, PA, CB, 5% Tint, System, TJ Gas Bezel, JKS Rear Trac Bar, Rusty's Front Trac Bar, KOR Stabilizer, Airaid, Hella 700's w/HID's, E-Fan, RCX Diff Guard, Clayton Brake Lines, Iron Man Extreme Control Arms, MSD, Gen Right Louvers, Custom Sliders, IRO Belly Skid |
#93 | |
Belief In All Things Jeep
1. towards motor
2. the thicker wire is high I'd go with a 50 amp fuse instead of 60 16 gauge for relay coil wiring, even 18 is fine. a relay coil only dissipates .6 watts Quote:
#94 | |
ill try out a 50amp fuse instead of the 60 and ill pic up some small wire as u stated would be fine for my switch. and i didnt notice the difference in gauge wires on the fan but i shall check it out since i havent given it a good look since i got it. im ordering a roll of 8 gauge wire and i was thinking about just using 8 gauge for both the high and low? jus so i can use all that i am ordering cause its in pre-set rolls. what u think?
#95 | |
Pretty sure one of the fan leads is 12 ga and the other 10 ga. The ground is 10 ga. Someone correct me if I am wrong. Sure you can use 8 ga for high and low, even tho it is hard to work with. Depending on how long the runs are, 8 ga might be overkill. |
#96 | |
#97 |
It will work great.
But 8 ga. is tough to work with is all. |
#98 |
Holy wire mess.... I will post pics from my e-fan install.
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009 98' ZJ STORM TROOPIN' SOLD 97' ZJ with 117K THE DD mi SOLD 01'WJ Project Cheap fix. |
#99 |
any wiring pics yet???
-98 ZJ I6: 30x9.5 BFG's, Wrangler blk wheels, roof rack, hitch, V8 steering for sale-> http://www.jeepforum.com/forum/f33/?uid=236207 |
#100 |
does the taurus 3.0l come with the same fan
#101 |
Pretty sure Its only the 6cyl (3.8L )
#102 |
Wheel Weber
#103 |
does any one know witch wire is high and low my ford tourus came with three wires the black is the ground i know that but one has a red strip and other has a yellow strip
can any one help thanks |
#104 |
ZJjazzyJim
Jump them straight to the battery one at a time - trust me, you'll know when you find the one that runs the high side - the assembly will try jumping up and biting you
![]() To answer the other questions, you want the fan from a 3.8. The 3.0 is a single speed fan, and does not pull as much air as the high side of the dual speed.
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#105 |
thanks i did just that. and now its all done
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
